Melted Coil Plug Harness?
My 93 Auto EB 4x4 just stopped running on the highway the other day. It seemed as if it wasn't getting either any spark, or any fuel.
Got it home, tried to start it again and it kinds of sputters like it wants to but it never fires. Looking under the hood, everything looks normal except for the wireing harness that runs into the ignition coil pack. The plug itself looks to be melted from the first two wires towards the front of the rig. The wires themselves have lost the plastic housing right where they run into the plug.
Has anyone ever seen anything like this before? I would have thought a fuse would blow before wires started melting? I am going to replace the coilpack and the plug of corse but something tells me that is not the source of my problems. Unless of course the coilpack is bad?
Thank you,
Just repair the coil, connector... and use some dielectric grease on the terminals.. you should be fine.
