Hard to start
Old Jun 20, 2010 | 01:15 PM
logger250's Avatar
logger250
Hard to start
1986 f250 6.9 New injection pump fuel filter glow plugs etc.. On a cold start truck is hard to fire up. After the glow plug light turns off it starts for about 5seconds then dies. I then have to hold the accelorator to the floor and turn it over for a bout 20 seconds before she will start. Why? When it is warm will fire up right away.
Old Jun 20, 2010 | 01:55 PM
Lazy K's Avatar
Lazy K
Sounds like you have air intrusion into the fuel system. First thing to do is to get a bolt or similar and block the drain pipe from the water seperator canister (mounted on firewall close to the drivers side inner fender).
Then consider ditching it altogether.
Also have a close look at the fuel return pipes at the injectors, may need replaced.
Old Jun 20, 2010 | 05:03 PM
94 smokin stroker's Avatar
94 smokin stroker
ya im with lazy k sounds like he is on the dot
Old Jun 20, 2010 | 05:04 PM
94 smokin stroker
how many miles etc
Old Jun 20, 2010 | 05:47 PM
rupejosh's Avatar
rupejosh
this is more than likely what you need.Pensacola Fuel Injection | Worlds #1 Diesel Rebuilder - FORD 6.9L - 7.3L :: INSTALLATION KITS
i would guess your return lines are wet between the injectors
Old Jun 20, 2010 | 09:45 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
If you still have the separator on the firewall between the brake booster and fender drivers side, you'll want to bypass and toss that POS, it'll give you nothing but trouble, even with the drain line plugged ... A bolt will not seal it.
Then use something like this Racor - Parker PF BF811 6.9L Ford Spinon.
-Enjoy
fh : )_~
sincecrazy
Jan 1, 2013 10:54 AM
F350mikey
Dec 23, 2012 09:19 AM
tpolley
32
Dec 9, 2009 09:47 PM
Chevy 6.2D
13
Feb 20, 2009 08:54 PM
n.o.yat
Oct 22, 2008 08:11 PM
