front parking lights not working
Old Jun 20, 2010 | 11:21 PM
wrd0225's Avatar
wrd0225
I have all lights working except front park lights. The turn signals work front and rear. The tail lights work. The headlights work. The fuses are good. Any suggestions? I would appreciate it. Thanks in advance.
Old Jun 20, 2010 | 11:33 PM
swooshcmk's Avatar
swooshcmk
Not trying to be an *** - did you check the bulbs? both filaments good?
And if so, the brown wire will be the wire for parking lights and you'll have to trace it back to where it doesn't work
Old Jun 21, 2010 | 12:00 AM
wrd0225's Avatar
wrd0225
I didn't check the bulbs. will do. I just didn't think they would burn out at the same time. Thanks
Old Jun 21, 2010 | 10:43 PM
PLC7.3's Avatar
PLC7.3
Have you checked the main light switch and it connector........ since you do not have truck info listed can't tell if it is applicable to yours. Check anyway.
Old Sep 30, 2014 | 10:53 PM
rollin_coal's Avatar
rollin_coal
Old post did you ever figure out what the problem was?
doublenickel
Nov 5, 2016 12:24 PM
chad77
Oct 3, 2016 01:11 PM
powerstrokeddiesel
1997 - 2003 F150
Feb 26, 2016 08:40 AM
htownoag
Dec 19, 2015 04:58 PM
blk450er
Aug 27, 2015 12:28 PM
