methanol injection
Old Jun 20, 2010 | 06:02 PM
poocher pup's Avatar
poocher pup
methanol injection
does anyone know if it would be of any real gain to run methanol in an 6.9l n/a idi. and if so how would be the best to spray it i.e. one big nozzlelike a fogger or eight smaller ones into each intake runner. any ideas on how much h.p. you would gain. also does anyone know of anybody running methanol on their truck as to side affects,cost? thanks for any advice.
Old Jun 20, 2010 | 06:06 PM
rupejosh's Avatar
rupejosh
methanol is another type of fuel without a turbo i doubt you would see any real gains that are worth while.by the time you piece together a methanol injection kit you probably could have bought a turbo kit anyway.the best thing you can do is turbo it.a few members have toyed with different injection systems but no longer run them because of the low gains and repairs that resulted because of it
Old Jun 20, 2010 | 06:16 PM
oreocreaming's Avatar
oreocreaming
x2. without a turbo you aren't going to see any gains. its main purpose is to drop the temps of the air going into the engine. your turbo pushes hot air into your engine, thats why newer diesels all come with intercoolers. they help drop the temp of the air before it gets shoved into your intake. methanol/water injection sprays in as a mist and brings that charged air temp down.
Old Jun 20, 2010 | 06:34 PM
poocher pup
yes i know ,have sprayed enough NOS into gas drag cars to understand what its trying to do. was wondered if built a cheap system if that would allow me to put more fuel in and keep temps down.
Old Jun 20, 2010 | 07:01 PM
Dean88's Avatar
Dean88
It won't help at all, because with a water meth kit you'll also be increasing the Compression ratio.
Old Jun 20, 2010 | 07:21 PM
oreocreaming
no, you will not help anything without a turbo.
Old Jun 20, 2010 | 07:51 PM
94 smokin stroker's Avatar
94 smokin stroker
ya and meth can be a killer on a diesel if overdone seen pics of some and basically engine boom and this YouTube - FUBAR METH ADDICTION KILLS DIESEL MOTOR
Old Jun 20, 2010 | 08:04 PM
oreocreaming
oh thats great.... A+ video man
Old Jun 20, 2010 | 08:09 PM
oreocreaming
nos is totally different, nos lowers the temp of any charge since it is so cold, making it more dense and letting it burn more fuel. meth is lowering only boosted charge and adding its own fuel to the mixture. its apples and oranges. now, apples to apples would be comparing nos to propane. both are a cold charge that lower a n/a or boosted applications air temp. propane acts as fuel and super cold charge to make the air more dense. again though, you will not see gains worth a damn without a turbo setup. sad to say there is no quick hp fix for these engines.
Old Jun 20, 2010 | 08:20 PM
94 smokin stroker
safest ways to make power in a idi - turn up ip once you got a pyro-add turbo-upgrade injectors-add intercooler from there idk much more oreo might but if you did that the idi you got would be all the power you could want
Old Jun 20, 2010 | 08:22 PM
94 smokin stroker
thanks oreo was just tryin to show how fickle that crap can be and how easily you can overdo it
Old Jun 20, 2010 | 09:26 PM
mabc926's Avatar
mabc926
If it's an everyday driver I don't see the point in adding meth to it.
Turbo, intercooler, turned up ip, bb code injectors, bigger exhaust, and that's all you need as far as power adders.
Old Jun 20, 2010 | 09:52 PM
94 smokin stroker
ya mabc926 is right on the money with me if you do all that power will be no problem fuel milage maybe a little depends on how you drive but you would be able to scretc the tires easily
Old Jun 21, 2010 | 09:23 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Well ill argue here i guess. You can keep adding fuel and making more power till you melt the engine down.. that is why it keeps getting hotter with more fuel... btu's are energy, energy is power. Thus, by using water/meth. you can add more fuel with less egts. Is this practicle w/out a turbo.. imo no. Hell for that matter only time it would be is for competition.
Old Jun 21, 2010 | 09:32 AM
87crewdually's Avatar
87crewdually
When you've done everything else and looking to keep the egts down pulling grade or whatever reason the system works. Whats scary is if you get a drippy squirter or pressure drop on the system and the water/methanol doesn't atomize.
Check out this tech article. It should answer alot of ?'s
Splash Water Methanol Injection
