2nd gear
Old Jun 7, 2006 | 09:34 PM
Jake S's Avatar
Jake S
2nd gear
Do all C6's go to second gear at any mph? I can start off from a stop in 2nd.
Seems funny. Is it normal?
Old Jun 7, 2006 | 11:08 PM
PLC7.3's Avatar
PLC7.3
The C6 trans is a three-speed unit capable of providing automatic upshifts and downshifts through the three forward gear ratios. The trans is also capable of providing manual selection of first and second gears.
Old Jun 8, 2006 | 07:18 AM
mistakenID's Avatar
mistakenID
If you manually put the C-6 in 2nd, it will start out in second and I believe it will hold that gear until you move the selector to Drive. I don't know if there is a pressure override that will make it shift to the next gear. The GM T-350 and 400 would hold a gear until it overrode and then bang into the next gear even if you had manually selected 1st or 2nd.
