F350 Sputtering
Old Jun 5, 2006 | 07:48 PM
AndysFords's Avatar
AndysFords
F350 Sputtering
I was in my 88 F350 (4x4, 7.3, C6) and it started sputtering like it was out of fuel. Then it cut off on me right in the middle of the road. My fuel gauge doesn't work so I thought it was out of fuel. I finally got it to the fuel station and it didn't hold but a little over a half a tank. What could be wrong? I think it might have an air leak, but if so, where? Where do these trucks normally get air leaks and how do I find out where it is. Also i think these problems are related to when I pulled my boat, a big 23 foot boat, my dad pulled the camper trailer in front of me with his 01 Powerstroke. That boat is big, but that Powerstroke left the little IDI on those hills. The camper weighs 18000 pounds, there is no way I shouldn't be able to pull that boat up that hill as quick as him with the trailer. What could possibly be the problem?
Old Jun 5, 2006 | 07:53 PM
bigblu78's Avatar
bigblu78
First off..... you don't stand a chance against that PSD on the hills.... You'll need several mods to pull that off... Change your fuel filter, check the tops of the injectors for fuel.. The o-rings may be leaking. Your lift pump may be getting weak as well.
Old Jun 5, 2006 | 07:55 PM
AndysFords's Avatar
AndysFords
When you have a boat that weighs 5,000 pounds vs a trailer that weighs 18000, I should have a chance.
Old Jun 5, 2006 | 07:58 PM
bigblu78's Avatar
bigblu78
My 88 with a c-6 is a monster as far as low end but it is worthless on hills.... that PSD has the ability to spool that turbo up and build that power.....
Old Jun 5, 2006 | 08:19 PM
AndysFords's Avatar
AndysFords
It may be the lift pump. I've been thinking about putting an electric pump on it. Is there any problems with putting an electric and a lift pump on the same truck? I believe I heard someone say that it might not be good. I had another truck with a lift pump and electric and it "ran away". I disconnected the electric pump assuming that was what it was, and have not had any more problems.
Old Jun 5, 2006 | 08:27 PM
bigblu78's Avatar
bigblu78
One or the other.... Put a block off plate where your lift pump is now and put an electric pump on.... Makes repriming it easier too....
Old Jun 5, 2006 | 09:29 PM
AndysFords's Avatar
AndysFords
what is a block off plate?
Old Jun 5, 2006 | 09:44 PM
bigblu78's Avatar
bigblu78
Its what you cover the hole in the engine with after you take off the lift pump..
Old Jun 5, 2006 | 10:13 PM
bcford6.9's Avatar
bcford6.9
Andy, I was following two friends, one with a 27ft 5th wheel, the other 26ft trailer, both towed by new 2005 & 2006 cummins. We were going on a flyfishing trip in the interior of BC...I had 4 boats, 2-10ft, 12ft and a 14ft...3 on a trailer and 1 off the front of my truck to my headache rack...they left me in the dust and I pushed that 6.9 for she was worth...but other than that the truck ran great...its 22 years old!
Old Jun 11, 2006 | 02:17 PM
AndysFords's Avatar
AndysFords
What if I just disconnect the fuel lines and leave the lift pump there pumping nothing. Would this not be better than a block off plate.
Old Jun 11, 2006 | 02:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Andy the block off plate is the same one used on a big block chevy motor.
It only costs a couple of dollars.
The fuel pump will suck in dirt and sieze up with no lines on it, why take a chance.
As far as keeping up with a Power Stroke, depending on the year it will have you out powered by somewhere between 40 and 115 HP.
The 88 was 185 HP the 96 was 225 the 2003 was 275 and the 2006 is over 300.
Your fuel problem may be cracks in the fuel pickup tube in the tank. Common problem and the gauge not working tells me it is about time for this problem to visit you. They both seem to happen close to each other.
Old Jun 12, 2006 | 11:03 PM
AndysFords's Avatar
AndysFords
Dave, that sounds like it could be the problem. I'm going to try that. Is the tube in the sending unit with the gauge?
Old Jun 13, 2006 | 07:29 PM
Dave Sponaugle
It all pulls out in one piece.
Close inspection or soapy water and bit of air pressure in the pickup tube will tell the story.
