Starting Point
Old Sep 26, 2024 | 05:13 PM
  #1021
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That was Roald Dahl I was quoting btw.
I knew you were well read.
And way above my head.
Nothing more need be said.
The warm man is now dead.
Time to re-rail this thread.
Old Sep 26, 2024 | 05:58 PM
  #1022
F350towing's Avatar
F350towing
Can someone have a look at the Version 2 document and see if it has uploaded properly.
I changed the layout a bit to hopefully make it more reader friendly, and corrected the 4- orb mistake.
Old Sep 26, 2024 | 06:17 PM
  #1023
RacinJasonWV's Avatar
RacinJasonWV
Yes it’s uploaded and will open in Safari browser. (but not Brave - issue with all FTE downloads now). Thanks again for doing this for the 7.3 community!
It looks like the original is still attached to the post as well. I think you’ll have to go into advanced mode during the edit to delete it.
Old Sep 26, 2024 | 06:20 PM
  #1024
F350towing's Avatar
F350towing
Thanks Jason.
I purposely left it in play based on your earlier caution.
Will edit the old document out later.
Old Sep 26, 2024 | 07:01 PM
  #1025
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Old Sep 26, 2024 | 07:15 PM
  #1026
RacinJasonWV
Guess I should have clarified. Brave on my old iPhone.
Proof I’m not a lion either. Not even with the Brave shield turned off.
It asks to download. I click it. It acts like it downloads and bounces me to the download folder. Nothing is there.
Been happening for over a week. I’ve just been copying the link and pasting in Safari as a workaround.
Sorry for the derailment Les.
Old Sep 26, 2024 | 07:16 PM
  #1027
John in OkieLand's Avatar
John in OkieLand
Originally Posted by Y2KW57
What F350towing prepared IS in fact a PDF.
Did you try clicking the PDF attachment link in F350Towing's post?
The image I posted was simply a screenshot of the index location of F350towing's post link in the Tech Folder.
The actual post, and the pdf itself, is "stored" in this thread, in F350towing's post.
My apologies for explaining that if you already understood. I explained it because I could not understand your stating that you much prefer a PDF, when that is exactly what was presented... a PDF.
I must have been asleep, missed the PDF link... will go back and get it.
Old Sep 26, 2024 | 07:32 PM
  #1028
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Brave works great on Android devices. Just sayin...
Old Sep 26, 2024 | 07:51 PM
  #1029
F350towing's Avatar
F350towing
I expect nothing less here. More or Les.
And now… back to the regularly scheduled program.
Old Sep 27, 2024 | 08:37 AM
  #1030
F350towing's Avatar
F350towing
Originally Posted by John in OkieLand
that is way too hard to follow,
I much Prefer a PDF that I can can all at once.
Your first comment did make me go back and take a closer look at how I had it laid out on the pages. I made some changes for the better in my opinion.
I truly hope you never have a need for that PDF.
Old Oct 1, 2024 | 12:28 AM
  #1031
F350towing's Avatar
F350towing
I never put a finger on the 7.3 this last weekend.
I looked over at it.
I cleaned up all the tools from previous weekends of working on it.
I arranged and cleaned all the parts that were swapped out in the low fuel pressure diagnosis.
I have developed a course of action for repair of the fuel pressure regulator.
But I did not touch the truck. Not even to turn the key.
I decided to do something on the Samurai instead.
After the spring over, and 3” leaf spring lift the driveline angle was at 13° on the rear axle.
I cut the perches off and rotated 10° to bring it back into spec. That should take care of the low MPH shudder.
Maybe next weekend I’ll feel like wearing diesel fuel cologne.
Old Oct 14, 2024 | 08:06 PM
  #1032
John in OkieLand
Originally Posted by Tpayne621
1984? Geez I wasn't even a stain on the bed sheet then. lol
is the .docx still available?
I like to EDIT remarks ref to my own truck, and highlight them in Yellow.
I use LibreOffice Writer, not MS useless blue screens of death.
Old Oct 14, 2024 | 08:29 PM
  #1033
F350towing's Avatar
F350towing
I will check if I saved the V2 as a .docx. I know for sure I have the PDF.
There are programs online that will convert for you if you would now prefer the Word over Adobe.
Old Oct 15, 2024 | 11:05 AM
  #1034
F350towing's Avatar
F350towing
John,
I just added the .docx to the original post that was linked into the tech folder.
https://www.ford-trucks.com/forums/1...l#post21353256
Old Oct 15, 2024 | 04:51 PM
  #1035
John in OkieLand
Originally Posted by F350towing
John,
thank you
thank you twice, Once is too short to post????
