Starting Point
Old Sep 24, 2024 | 07:24 PM
  #1006
F350towing's Avatar
F350towing
Originally Posted by Y2KW57
It's worse than that.
Much worse.
I can still think of things I wanted to do in 1984 that I haven't done yet.
That's 14,600 days late ago.
Not sure that I am capable of compounding the interest on all those dollars shorted.
Damn, 1984… I was 15 and rebuilt my first 2-stroke.
Isn’t there a statute of limitations on procrastination?
Don’t keep lists. Those are just bad reminders of stuff that didn’t get done.
Allow the forgetter to do its job.
My forgetter’s getting better, and my rememberer is broke.
My wife hates it, but I can live in bliss.
Old Sep 24, 2024 | 08:46 PM
  #1007
Tpayne621's Avatar
Tpayne621
1984? Geez I wasn't even a stain on the bed sheet then. lol
Old Sep 25, 2024 | 11:50 AM
  #1008
F350towing's Avatar
F350towing
@Y2KW57
Here is my final draft for this document.
I took a look in the tech folder on my mobile device and found that PDF files opened up easily. The .docx wouldn't open on my iPhone so I converted it to a PDF.
By request I have also added the .docx document that can be saved to your device and edited.
Last edited by F350towing; Oct 15, 2024 at 11:00 AM. Reason: Edit: Inserted the .docx version
Old Sep 25, 2024 | 12:12 PM
  #1009
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
And it's in the Tech Folder already!
Imagine that?
Fuel Related Section of the Tech Folder
The 7.3L PSD communities, both here and elsewhere, both now and in the future, thank you for your contribution to the collective knowledge base.
It takes time to write things up, so we take time to appreciate you for doing so.
Old Sep 25, 2024 | 04:40 PM
  #1010
John in OkieLand's Avatar
John in OkieLand
Imagine that?
that is way too hard to follow,
I much Prefer a PDF that I can can all at once.
Old Sep 25, 2024 | 08:29 PM
  #1011
F350towing's Avatar
F350towing
So you want a PDF that you can dance on?
I struggled with how to write it up.
I could have just made a simple one page flow chart but my goal here was to create a step by step guide with the procedures for the diagnosis. Follow the steps, find your problem.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life
Old Sep 25, 2024 | 10:40 PM
  #1012
FordTruckNoob's Avatar
FordTruckNoob
Also:
Light a fire for a man, he stays warm for a night.
Light a man on fire, he stays warm for life.
Old Sep 25, 2024 | 11:28 PM
  #1013
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Also:
It's a very short life, but at least he is warm?
Old Sep 26, 2024 | 12:26 AM
  #1014
F350towing's Avatar
F350towing
Also:
Extreme, but also a true statement.🔥 🔥
He was so bright, too bad he burned out so soon.
Old Sep 26, 2024 | 05:31 AM
  #1015
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Bah-dum-dum..
Old Sep 26, 2024 | 07:25 AM
  #1016
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
What F350towing prepared IS in fact a PDF.
Did you try clicking the PDF attachment link in F350Towing's post?
The image I posted was simply a screenshot of the index location of F350towing's post link in the Tech Folder.
The actual post, and the pdf itself, is "stored" in this thread, in F350towing's post.
My apologies for explaining that if you already understood. I explained it because I could not understand your stating that you much prefer a PDF, when that is exactly what was presented... a PDF.
Old Sep 26, 2024 | 08:25 AM
  #1017
FordTruckNoob
Exactly. That was Roald Dahl I was quoting btw.
Old Sep 26, 2024 | 09:02 AM
  #1018
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I think it looks great, easily understanded and even has pictures for people like me that can barely read...
Well done Les and we are grateful for your efforts.
Old Sep 26, 2024 | 10:09 AM
  #1019
F350towing's Avatar
F350towing
I had been alerted to the fact that not all my information was 100% correct.
The ORB at the fuel bowl ports are in fact a 4- not the 6 as it is was originally written. Thanks Jason. I had to go back and check my receipts to confirm.
This has been corrected on the current posted version.
The beauty thing about the way Y2K has linked it, I can easily modify the document and put the replacement into the linked post.
Old Sep 26, 2024 | 12:08 PM
  #1020
RacinJasonWV's Avatar
RacinJasonWV
Little heads up about deleting and then uploading a replacement file. When I do that on the matrix, the system freaks out and doesn’t “finish” the upload. BUT it will still be there after submitting the edit. Not sure why it does this but didn’t want you to waste a bunch of time trying to get it to upload like I have in the past. If it does that, try saving your edit and see if it’s there afterwards.
