Official NCFTE Works Thread
Old Dec 11, 2017 | 06:28 AM
  #1351
FordTruckfan89's Avatar
FordTruckfan89
We spent the weekend pulling a well pump, crappy weather Friday and Saturday. After fixing some pipe connections, new pump and new wire, it's back working again.
Old Dec 11, 2017 | 07:31 AM
  #1352
FuzzFace2's Avatar
FuzzFace2
Originally Posted by FordTruckfan89
Like a biocide?
I guess but made for fuel oil.
Now with biocides the stuff you are trying to kill gets use to it so needs to be changed up from time to time, at least in water treatment.
Dave - - - -
Old Dec 11, 2017 | 08:50 AM
  #1353
fuzzy1626's Avatar
fuzzy1626
Originally Posted by Benztechnc
Wesley bought the F250 over tonight. Tested various things, but finally settled on engine or injectors. Started pulling the injectors and found this:
so it’s sitting and waiting on parts. Might be able to clean them but planning on just replacing them.
What engine?
Old Dec 11, 2017 | 09:21 AM
  #1354
Benztechnc's Avatar
Benztechnc
Originally Posted by fuzzy1626
What engine?
Tony, Wesley's F250 has the 5.8 in it. The passenger side bank was difficult to get to because the intake was in the way. It just took longer than expected is all.
Old Dec 11, 2017 | 09:16 PM
  #1355
FordTruckfan89
Dave - - - -
I know there's lots of additives to remove water from fuel for diesel fuel. For gasoline, I have no idea.
Old Dec 15, 2017 | 09:34 PM
  #1356
FuzzFace2's Avatar
FuzzFace2
I thought that filter was from a diesel not a gas motor as I have never seen a gas filter that bad with sludge.
Other than dry gas for water I don't know what else they make.
Now dry gas is alcohol so I wonder if you where to add say a gal. of E85 what that would do?
But it looks like the tank has rusted so I would replace it if you can and get rid of the gas you have now for fresh stuff and from a different station than you et gas from as the water had to come from someplace.
Dave ----
Old Dec 16, 2017 | 10:44 PM
  #1357
FordTruckfan89
Picked up a 5 gallon air tank and some 10" brackets from Lowe's, looks like I'll have to drill 2-3/8s frame holes, but two line up perfect. Still debating on mounting the air compressor in the toolbox, which makes running the air line and wires a pain or put it under the truck, but it'll be exposed to weather a bit more.
Old Dec 17, 2017 | 03:52 AM
  #1358
Cracker289's Avatar
Cracker289
Helping a friend with a 93 F250 with 351w (5.8) engine; harmonic balancer came apart and beat the crap out of the timing cover. When he removed it, it came off in 2 pieces. Top part completely broke away from the bottom! Him & his brother did not know how to remove a harmonic balancer, so they beat & pried on it until the oil pan was a dented mess. I pulled the balancer off in 3 minutes, he was amazed like I was Criss Angel or something. I think they must have left the bolt on while they were fighting it. Anyway never seen anything quite like this. But we ran out of daylight (and it started getting cold!) so we didn't get the job finished yet. But this was what I walked into:
Old Dec 18, 2017 | 06:24 AM
  #1359
FordTruckfan89
That looks fun John. Can anyone recommend a radiator shop that could braze/solder in a replacement petcock on a brass radiator? The "fix" I did on mine has a real slight leak.
Old Dec 18, 2017 | 08:36 AM
  #1360
Benztechnc's Avatar
Benztechnc
Vintage John,
Looks like you gone and broke something in that engine.
Sorry Dusty, I've never had a radiator repaired.
Old Dec 18, 2017 | 09:09 AM
  #1361
FordxFour's Avatar
FordxFour
Dusty, I used to take my radiators to this place. It's been about 11 or 12 years ago since I've been there. The last one I took to get the whole core(4 row)replaced for a class A motorhome that we owned. I had no choice because it was an odd ball and I couldn't find one anywhere. Later on I found out that it was a custom made radiator specifically manufactured for the coach builder. Good luck...get a price before you leave it. You may be shocked and find out that it's cheaper to replace it. I have no idea what prices are these days.
Sapps Welding & Radiator Service
1501 Mechanical Blvd, Garner, NC 27529
(919) 772-3966
Old Dec 18, 2017 | 09:22 AM
  #1362
FordTruckfan89
(919) 772-3966
Unfortunately they are out of business.
Old Dec 18, 2017 | 09:29 AM
  #1363
FordxFour's Avatar
FordxFour
I did not know that, it's a shame. Finding anyone these days that can braze thin brass without getting heavy handed with a torch and burning a hole through it may be tough. I'll check with a couple of folks that I know that may know someone that can do it.
Old Dec 18, 2017 | 09:39 AM
  #1364
FordTruckfan89
Willie suggested a place that does welding, just not sure if he can/ is used to doing radiators.
Old Dec 18, 2017 | 01:05 PM
  #1365
dlibson's Avatar
dlibson
Worse comes to worse there is a place on Wilmington that does them. I can get the info if you need it.
