Engine removal pics
Old Nov 26, 2012 | 07:43 AM
  #1081
2006lariat's Avatar
2006lariat
It is amazing how fast you are getting the "Lego" engine back together! WOW
I kinda like how it look's. Don't pop the hood at a gay pride event though! lol
Seriously, It is awesome!
Old Nov 26, 2012 | 08:17 AM
  #1082
bismic's Avatar
bismic
What a fantastic job you have done Anthony. You should have someone take a video of the start-up for us!!
I can't wait for you to turn the key!!!
Old Nov 26, 2012 | 08:52 AM
  #1083
daddykitty's Avatar
daddykitty
I think I just saw Richard Simmons checking out your engine color scheme a few pages back
Old Nov 26, 2012 | 09:46 AM
  #1084
m-chan68's Avatar
m-chan68
Originally Posted by run6.0run
Is there a quick way to bypass the clutch safety switch???? Wouldn't mind firing it up before the trans goes back in. In case those coolant lines leak, actually in case anything leaks.
That actually wouldn't be a bad idea. You don't need to worry about the clutch safety switch. Simply turn the ignition key to the run position and jump the starter directly with the jump starter wire jumped to the passenger side battery positive terminal.
Old Nov 26, 2012 | 11:39 AM
  #1085
run6.0run's Avatar
run6.0run
I've heard about that wire,,, but never seen it. Isn't it a green wire or something on the pass inner fender??? Anyone got a pic of it???
Old Nov 26, 2012 | 12:13 PM
  #1086
m-chan68's Avatar
m-chan68
Look in your engine compartment by the vacuum pump. There will be a heavier gauge wire with a "squeeze and pull" type connector. Disconnect the two halves and jump the male end of the wire to the passenger side positive terminal to engage the starter.
Better yet, you still have your engine compartment and wiring all apart. Follow the one wire that connects to the 's' terminal on the starter solenoid and you will see what I'm talking about. The wire colour is yellow with a light blue stripe.
Old Nov 26, 2012 | 02:31 PM
  #1087
Skip1970's Avatar
Skip1970
wholly clown color engine batman!
Old Nov 26, 2012 | 03:39 PM
  #1088
Yahiko's Avatar
Yahiko
Anthony,
Are you going to pre-fill the HPOP? I would think a little less time
of sucking air would be better for it. Even if you don't let it start.
That way you don't run your batteries down with the priming run.
Sean
Old Nov 26, 2012 | 07:33 PM
  #1089
Piolet's Avatar
Piolet
+1 ... it'll be criminal if this isn't recorded for posterity.
Old Nov 26, 2012 | 07:44 PM
  #1090
run6.0run's Avatar
run6.0run
Got some pics
Here's how I had to strap it until I hooked up the down pipe
Back driver side of the heat shield. I routed the coolant line there
Kinda hard to see what is goin on huh
Old Nov 26, 2012 | 07:47 PM
  #1091
run6.0run's Avatar
run6.0run
The foil wrap on the ipr valve
Tryin to keep them from seizing.
I coated the inside of the oring with oil,,, but figured grease would work great
Old Nov 26, 2012 | 07:49 PM
  #1092
run6.0run's Avatar
run6.0run
Can you see the threads that popped outta the nut. Crazy,,,, I looked at the wrong torque spec.
  #1093
run6.0run's Avatar
run6.0run
We've got fuel!!!!
Old Nov 26, 2012 | 07:50 PM
  #1094
run6.0run's Avatar
run6.0run
Here's a good look at the top side of my ccv reroute
Old Nov 26, 2012 | 07:51 PM
  #1095
run6.0run's Avatar
run6.0run
Anti seize everything on the exhaust
