I am keeping the coolant recirculating kit. But ditching the steel braided lines. I'm putting threaded barbs in the heads and using hose clamps and rubber hose. When I had to fix the leaking line in Edmonton ab,,, it suked
Rusty, It's Loctite. But I thought that they had done away with that need.
I know that the rear one they did. The tools are so COOL AND HANDY I like my set.
Things will really start to move at this point. Just take your time
I just looked at Srmastertech 6.0 on Youtube and all he said
was install the valve components in the same location
The I got the 3 book set out and looked in the engine section and found the same
thing SO I get the Panasonic Tough Book laptop with the Ford DVD out and
look there. Same thing .
Guess we will have to wait for M-chan or see if you have it in one of your photos.
One hint with small things like the bridges when I take then apart I make a note as to
the orientation just incase ( I know it's too late now)
