Engine removal pics
Old Nov 29, 2012 | 10:10 AM
  #1186
run6.0run's Avatar
run6.0run
Blue springs ford has both wires in stock. Might as well replace them too. What do u guys think??? Just another hundred dollars.
Old Nov 29, 2012 | 10:14 AM
  #1187
run6.0run's Avatar
run6.0run
Wonder how much it would cost to build a truck with new ford parts????? 100k????
Old Nov 29, 2012 | 10:43 AM
  #1188
CPB1's Avatar
CPB1
Originally Posted by run6.0run
I will help in any way I can,,,,, I will definitely still need help to tho. Like right now,,,, my glow plugs are sick. Does the gp control module either work or not??? I reused the wires also. I'm debating on replacing the wires,,, unless someone else has had a gpcm turn weak. Gp's are new
You can ohm out the Glow Plugs to see if the harness is good. Test each lead of the Glow Plug harness to ground, or Neg Batt post. It should be about 2 ohms.
Chuck
Old Nov 29, 2012 | 11:12 AM
  #1189
m-chan68's Avatar
m-chan68
Before you jump the gun, what is your issue? P0670 and/or P0683 setting?Did this just happen after your #1 injector replace? Did you plug the black and green connectors into the GPCM properly after you re-installed the passenger side valve cover? I know those connectors are a little stiff, but will set those codes if they aren't seated properly into the module.
Old Nov 29, 2012 | 11:20 AM
  #1190
run6.0run's Avatar
run6.0run
Gotta love that owner advantage deal the dealerships have. I just got both gp harnesses for $28
Old Nov 29, 2012 | 11:21 AM
  #1191
run6.0run's Avatar
run6.0run
I wish I had codes. They worked, just not very well. This is the first time I've ever tried to reuse the wires,,, and it will b the last....
Old Nov 29, 2012 | 11:24 AM
  #1192
run6.0run's Avatar
run6.0run
It happened from the initial fire up. I did take ur advice n not reuse the plugs,,,, so they are new.
Old Nov 29, 2012 | 11:28 AM
  #1193
run6.0run's Avatar
run6.0run
Once I get back to the truck, I will check the ohms. I did get the harnesses clicked in on the gpcm. I know my track record isn't very good... I'm thinking that even tho the wires looked good, I must've broke something in the ends when I disassembled. Unless, a gpcm can be weak, or does it work or not???
Old Nov 29, 2012 | 12:23 PM
  #1194
CPB1's Avatar
CPB1
Make sure you have a good ground from the engine back to the Neg Batt, or frame ground. You need to get onto clean metal. The paint looks great but not very conductive.
Chuck
Old Nov 29, 2012 | 12:25 PM
  #1195
m-chan68's Avatar
m-chan68
Check pins #3 and #17 of the middle PCM connector for continuity to the one GPCM connector. Wire colours are violet with orange stripe and white with light green stripe. If those circuits are good and all eight glow plug circuits check out to less than 2.0 ohms, replace the GPCM.
Old Nov 29, 2012 | 08:47 PM
  #1196
run6.0run's Avatar
run6.0run
Very great info,,, thx Mike. I took a screen shot of that post. I will check that later. I opted to listen to advice, and calm down with the breakdown. I left it alone for now. I drove it today.
Old Nov 29, 2012 | 08:48 PM
  #1197
run6.0run's Avatar
run6.0run
I did a bunch of finishing touches today.
Here is what my power steering fluid looked like
Old Nov 29, 2012 | 08:50 PM
  #1198
run6.0run's Avatar
run6.0run
I finished flushing it all out and got the level right
Here's the headlight support. I only paid $80 for it. Brand new. But it didn't have any brackets or clips with it
Old Nov 29, 2012 | 08:52 PM
  #1199
run6.0run's Avatar
run6.0run
I figured,, what the hell,,, zoodad is what they call it huh
Here's the brackets I had to rob off the old support from the 04
Old Nov 29, 2012 | 08:54 PM
  #1200
run6.0run's Avatar
run6.0run
Can you see where my cac got damaged
I was worried about the line to the left,,, tight clearances. I bent the bracket to the ac condenser to get some room
