Engine removal pics
Old Nov 23, 2012 | 05:26 AM
  #1021
Jigger2020's Avatar
Jigger2020
Lookin great Runner
Old Nov 23, 2012 | 05:57 AM
  #1022
mustang_309's Avatar
mustang_309
Man Anthony that looks Fantastic, i sure hope it runs as good as it looks. Looking forward to the first start video. And thank you again for taking the extra time to document your progress.
Old Nov 23, 2012 | 10:54 AM
  #1023
Piolet's Avatar
Piolet
Originally Posted by run6.0run
Now would be a great time to write that serial number down. Might help down the road, cause once she goes in to the truck I don't think you'll ever see it again.
Old Nov 23, 2012 | 10:57 AM
  #1024
Piolet's Avatar
Piolet
I'm drawing a blank,,,, it's late tho. What goes here????
I believe one of the 5 fan shroud bolts will be going in there.
Edit: In some of the descriptions I read before I was removing mine for some front work, they were calling for removing the 4 bolts .... my 2003 had 5 .... oh well.
Old Nov 23, 2012 | 11:20 AM
  #1025
run6.0run's Avatar
run6.0run
Oh I sooooo happy,,, blue springs ford to the rescue,,,,, they had it on the shelf
Old Nov 23, 2012 | 11:25 AM
  #1026
Jigger2020's Avatar
Jigger2020
Good stuff, now you can forge ahead........
Old Nov 23, 2012 | 11:28 AM
  #1027
cheezit's Avatar
cheezit
The manual says to put the copper side up,,,, but said the late models didn't have the copper tips.
pushtubes go copper side up, bridges can go either way but i perfer the oval hole to the top.
Old Nov 23, 2012 | 12:10 PM
  #1028
Jigger2020's Avatar
Jigger2020
Cheezit what do you think is going on with the crushed rocker plate dowel/sleeves....thx for your input, we appreciate it a lot
Old Nov 23, 2012 | 01:01 PM
  #1029
run6.0run's Avatar
run6.0run
Very cool,,, thx cheezit,,,,, I actually put the oval towards the center.
Old Nov 23, 2012 | 03:22 PM
  #1030
m-chan68's Avatar
m-chan68
That would be where one of the two idler pulleys bolts onto, on vehicles equipped with dual alternators.
Old Nov 23, 2012 | 03:23 PM
  #1031
m-chan68's Avatar
m-chan68
The dowels that go that locate the rocker arms only go on the end rocker arms at all four corners.
Old Nov 23, 2012 | 03:57 PM
  #1032
run6.0run's Avatar
run6.0run
Thx Mike,,,, so It looks like everything is in order on my engine. It's wierd that my new center rocker arm assemblies came with dowels then. They didn't fit in the holes,,,, Oh well.
Btw, I just got a new 175 btu heater for 135. I think I'm takin tonight off tho. Havin a little get-together.
Old Nov 23, 2012 | 04:14 PM
  #1033
Jigger2020's Avatar
Jigger2020
Go have fun Runner, you deserve it
Old Nov 23, 2012 | 04:25 PM
  #1034
davbeisner's Avatar
davbeisner
Curious what that coolant recirculating system is you're talking about there, that's threaded into your head... That's not an OEM part of the system, is it?
Old Nov 23, 2012 | 05:34 PM
  #1035
run6.0run's Avatar
run6.0run
No it's not stock. There was talk a coue years ago about the coolant dead heading around cylinders 7 n 8. This kit gives the coolant a place to go at the back of the block. I threaded lines into the back of the heads, and originally they threaded into the thermostat housing in the front cover. I'm gonna change it and thread the lines into the coolant bottle,,,, then I can see how much coolant actually flows through there. I used to have steel braided lines,,, which were cool, but I think they are good for short term extreme duty. I had one line start leaking. The braids were breaking, and puncturing the hose,,, causing a soaker hose effect. Not cool. I'm goin back with regular rubber hose with hose clamps. Ole faithful. I also got some hvac tape that in gonna wrap the hoses with to try n battle the heat that's back there. We will c how it works.
