Very cool,,,, I remember making all three connectors click. But,,,,,, here we go with another screw up!!!!
I need to quit bein so quick to take this apart.
I was worried about that injector cup. I took it down,,, got ready to unplug the #3 connector,,,,,,,,, it's not even plugged in. Wow,,, I was bout to remove the ac box n take the head off(which this doesn't mean it's not still coming off). But I hope not. I'm so freakin used to having my truck down,,,, I don't think I want to finish it????? Not really tho. The #1 injector is one of my original ones (582k). Since 3 n 1 aren't next to each other in the firing order, I'm thinking about changing #1 n leaving 3 in. Would u guys go ahead n pull 3 to check it out??? I did send the wife up just before they closed n got 2 ford injectors. Could change em both, but 3 could still b good.
Anthony,
You did not say what was the problem with the starter spinning on
it's own. Or did O just miss that ?
Now that you have the wrappings off the truck and you see the yellow
under body paint?
Anthony,
under body paint?
Sean
I don't know what it was?????? I took out the starter, n put it back in... I must've had the angled piece of the small wire touching something? I also didn't have the small power line hooked up on the driver side (I think it runs the computer n everything.)
