It looked like lock tite but it must be lubricant huh....I hope
No,,,, it was loctite. Even if I didn't need it,,, oh well, I have the remover tool also. And I've got 2 front crank seals lol. One came with the overhaul kit,,, n one with the front cover
Is it too late to pull the seal back out & wipe the lock tite off, the seal is gonna stick to the crank & you dont want that...it should be lubed there.....am I wrong, just my .02
I'm now wondering about the dowels that came with the rockers. The main plate doesn't sit flat on the rocker box with the dowel on the stud. The dowel doesn't fit in the hole of the rocker
Here's a pic of the dowel
N here's what happens when I tighten it on the dowel
I've got extra dowels tho. But I'm bout to just leave em off in the centers. The dowels on the sides were never removed from the rocker boxes and fit fine.
Yeah,,,, I think ur wrong. I loctited the wear ring to the crank. The seal spins on the wear ring
At least I hope ur wrong tho,,,, no offense I hope
