Engine removal pics
Old Nov 20, 2012 | 05:48 PM
  #946
Jigger2020's Avatar
Jigger2020
Great pics, thanks for sharing, much appreciated...........
Old Nov 20, 2012 | 06:45 PM
  #947
daddykitty's Avatar
daddykitty
YELLOW??? WTF!!! I really hope you don't break out the rainbow colors
Old Nov 20, 2012 | 07:30 PM
  #948
Skip1970's Avatar
Skip1970
that is one wide oil pan!!!
Old Nov 20, 2012 | 07:35 PM
  #949
Jigger2020's Avatar
Jigger2020
Big oil pan holds about 15 quarts huh
Old Nov 20, 2012 | 09:19 PM
  #950
MisterCMK's Avatar
MisterCMK
I hope you remembered to sign you name on the upper oil pan before you bolted it up.
Old Nov 20, 2012 | 09:31 PM
  #951
johnblade's Avatar
johnblade
Good luck,I've been waiting for the rebuild!
Old Nov 20, 2012 | 10:15 PM
  #952
run6.0run's Avatar
run6.0run
Patience,,,,,, there's 3 more colors,,,, I didn't plan on yellow for the pan, but I wanted to have a bright color so when I shine a flashlight under there,,,, it would help illuminate. U don't like?????? Lol
Old Nov 20, 2012 | 10:22 PM
  #953
zhilton's Avatar
zhilton
And here I thought you liked Dozer Motors (Caterpillar)...thus the yellow. Sort of looks like the correct shade on my screen. We are talking about a HUEI engine after all.
Old Nov 20, 2012 | 10:25 PM
  #954
daddykitty's Avatar
daddykitty
ummm....3 more colors would make a rainbow...this thread just got a little gay...lol
Old Nov 20, 2012 | 10:36 PM
  #955
Yahiko's Avatar
Yahiko
Well at least it will match my truck body paint.
A all white engine would look different. Just something to ponder,
Sean
Old Nov 21, 2012 | 02:27 AM
  #956
run6.0run's Avatar
run6.0run
Are we a bit homophobic?????? I like the yellow,,,,
Old Nov 21, 2012 | 03:58 AM
  #957
Skip1970's Avatar
Skip1970
might as well put a cummins in it now that all the rainbow colors are out.
Old Nov 21, 2012 | 05:07 AM
  #958
npccpartsman's Avatar
npccpartsman
Anthony:
I meant to ask if there were gaskets or o-rings for the piston cooling jets and if so did you have the part number or did they come in the gasket kit???
Old Nov 21, 2012 | 10:34 AM
  #959
run6.0run's Avatar
run6.0run
Originally Posted by npccpartsman
Anthony:
I was concerned about that!!! But they were just locktited stock with no orings or gaskets. I didn't have anything in the kit to seal them. I'm thinking they are just metal on metal sealing. Kinda odd,, I will have to look at my pics n see if the jets slide into the block through the mounting bracket. I think they did.
Old Nov 21, 2012 | 10:40 AM
  #960
run6.0run's Avatar
run6.0run
I'm thinking about keeping the coolant recirculation kit,,,, except I'm wanting to plumb the lines from the back of the heads into the radiator to degas hose. Reason being is my heads already have the holes threaded n my new front cover doesn't. It would be easier to fix on the road if I have a leak on hose barbs, rather than at the front cover,,, that is if I thread into the tstat housing. I'm also thinking about plain rubber lines with wire looms on them. What do u guys think??
