Engine removal pics
Old Nov 15, 2012 | 07:19 AM
  #931
Fulthrotl's Avatar
Fulthrotl
Originally Posted by Rusty Axlerod
A micrometer and dial bore gauge (and a skilled pair of hands) are more accurate than plastigauge. With the manual gauges it's common practice to measure in multiple places around the diameter, the plastigauge measures only where you put it. You are more likely to find distorted main caps for example when using the old school method.
for most folks, who don't build engines for a living, the plastiguage
is what's gonna happen. for checking concentricity, you have to fit
everything and torque it to specified values, then use the bore gage.
a 2"~4" mitutoyo bore guage is $4,783. the plastiguage is $7.
i've put together motorcycle engines with a 12,000 rpm redline
with plastiguage, and it's always worked for me. if i want to be really
****, i can check it three times, rotating the shaft a third of a turn,
and get a pretty good idea of running fit.
obviously, it won't work on cam bearings, but any shop with the
necessary equipment to replace cam bearings knows how to scrape
and dychem them to check for fit.
MITUTOYO Bore Gage Set, Borematic, 2-4 In - Hole, Drill, Bore, and Wire Gauges - 5RCG0|568-936 - Grainger Industrial Supply
Old Nov 15, 2012 | 09:22 AM
  #932
John Diem's Avatar
John Diem
Mitutoyo Makes a non digital bore gauge for thousands less. Mine was $250.00 30 yrs ago.
Old Nov 15, 2012 | 09:48 AM
  #933
sscarboro's Avatar
sscarboro
$250 30 years ago would be $2500 today no doubt.
Steve
Old Nov 15, 2012 | 09:58 AM
  #934
John Diem's Avatar
John Diem
STARRETT Bore Gage Set, 2-6 In, 0.0005 In Grad $336.00 Well known tools
Old Nov 15, 2012 | 09:47 PM
  #935
daddykitty's Avatar
daddykitty
^^^^^^^^^^^x3
Old Nov 20, 2012 | 01:19 PM
  #936
run6.0run's Avatar
run6.0run
I've got some pics,,,, my tools are 600 mi away tho,,, long story. I've got the engine n heads back
Loaded in the truck
Here's all my old crap
The lifting bracket is great. All trimmed up so I can put the hpop n oc covers on
Who's got new pistons????
Delta camshaft only charged me 150!!!! Wow
The shop listened and put permatex on the bed plate. That's per the sr master tech video.
Wow,,, I'm finally gonna have a truck
Everything except inj cups are new
Time to get her on the stand n flip her to do the oil pans
Old Nov 20, 2012 | 01:22 PM
  #937
King-bRanch's Avatar
King-bRanch
Glad to hear things are happening again for u....Good Luck & keep us posted
Old Nov 20, 2012 | 01:46 PM
  #938
npccpartsman's Avatar
npccpartsman
I'm jealous Anthony--LOL. That's looking good for sure
Old Nov 20, 2012 | 01:53 PM
  #939
MisterCMK's Avatar
MisterCMK
Why didn't you have new injector cups put in?
Old Nov 20, 2012 | 02:25 PM
  #940
Crash16's Avatar
Crash16
Finally, I've been waiting for this. Lol. Best of luck to you Anthony.
Old Nov 20, 2012 | 03:20 PM
  #941
Yahiko's Avatar
Yahiko
Anthony,
SWEET
One just has to ask why are your tool 600 miles away??
Sean
Old Nov 20, 2012 | 04:58 PM
  #942
run6.0run's Avatar
run6.0run
All the talk about replacing the heads rather than just the cups. I've not had an issue with them yet. I didn't want to cause an issue. It's definitely still an option, if you guys don't think it will cause a prob. Maybe Mike will chime in on this.
Old Nov 20, 2012 | 04:59 PM
  #943
run6.0run's Avatar
run6.0run
Originally Posted by Yahiko
Anthony,
SWEET
Sean
Yeah,,,, um,,,,,, don't ask. Lol,,, good news is now they are 300 mi away.
Old Nov 20, 2012 | 05:10 PM
  #944
run6.0run's Avatar
run6.0run
Ok more pics
Cleaned up the block-upper oil pan joint
One last look b4 buttoning it up
Here's the upper oil pan
10 ft lbs on all of this
Old Nov 20, 2012 | 05:14 PM
  #945
run6.0run's Avatar
run6.0run
Here's another look inside the oil pan
All the bolts labeled with a 1 get the longer bolts
Here they are
10ft lbs also
Almost done
There we go,,,,
