Engine removal pics
Old Nov 28, 2012 | 03:30 PM
  #1141
run6.0run's Avatar
run6.0run
Starter is back in,,,, all is well,,, so far
Old Nov 28, 2012 | 03:40 PM
  #1142
daddykitty's Avatar
daddykitty
where did you get that snap on pressure guage for the degas bottle? that might be a handy thing to have for a just in case
Old Nov 28, 2012 | 03:51 PM
  #1143
Yahiko's Avatar
Yahiko
Here is one on Ebay
Snap-On Cooling System Refiller Tool Fill Air Lift Coolant Radiator SVTSRAD262A | eBay
Cheeper one
http://www.ebay.com/itm/PBT-QUICKFIL...5c4c1b&vxp=mtr
To save a little cash you can get a non Snap-On one they all do the same job
Sean
Old Nov 28, 2012 | 04:11 PM
  #1144
run6.0run's Avatar
run6.0run
Does it start????? Or did it blow up???? Suspense
http://youtu.be/zHr5w_LDcKU
Old Nov 28, 2012 | 04:14 PM
  #1145
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
<fiiilll>
Old Nov 28, 2012 | 04:31 PM
  #1146
run6.0run's Avatar
run6.0run
Here's another
http://youtu.be/OkLVc9BWOnQ
Old Nov 28, 2012 | 04:32 PM
  #1147
run6.0run's Avatar
run6.0run
I found it on eBay. Hundred dollars. It's a snap on radkitplusa
Old Nov 28, 2012 | 04:34 PM
  #1148
run6.0run's Avatar
run6.0run
Originally Posted by raptor131
Glow plugs making noise, you mean the injectors buzz? If not check ficm connectors make sure they are seated
I don't have any of those flashes. It's still got the factory flash with no buzz or preheating. The glow plugs are coming on,,, but sound sick
Old Nov 28, 2012 | 04:35 PM
  #1149
run6.0run's Avatar
run6.0run
Originally Posted by Crash16
I have to ask, where did you get the diamond plate filler panel for the conversion on your 04?
I scored it off Craigslist,,,, in Michigan. The guy made it himself,,, and sold me the entire bumper with all brackets for 300
Old Nov 28, 2012 | 04:39 PM
  #1150
m-chan68's Avatar
m-chan68
That sounds a little rough Anthony. What's the Check Engine light coming on right away for?
Old Nov 28, 2012 | 04:53 PM
  #1151
run6.0run's Avatar
run6.0run
Looks like I might have inj 1 & 3 out. I need to get an extra anyways. Not getting a contribution balance,,, just inj circuit low,,,, that might be a connection huh???? I'm gonna let it cool down n check the connections
Old Nov 28, 2012 | 04:54 PM
  #1152
run6.0run's Avatar
run6.0run
The check engine is from the egr delete normally. It comes on about every 5th start or so. But I'm getting inj codes.
Old Nov 28, 2012 | 05:06 PM
  #1153
run6.0run's Avatar
run6.0run
Oh man,,,, I am just thinking,,, hope my decision to not put inj cups in isn't the issue. They looked clean, but #3 was the cup that has the copper washer messed up. I'm gonna get #3 out now n see if its burnt
Old Nov 28, 2012 | 05:55 PM
  #1154
Jigger2020's Avatar
Jigger2020
I'm glad to see & hear it run Anthony, very well done so far & good luck with the injectors...
Old Nov 28, 2012 | 06:01 PM
  #1155
bezzy's Avatar
bezzy
Is this work being done in your driveway? How on earth do you have the time to do this yourself? Looking at your photos only reminds me all the more clearly why I lift cabs to replace engines on these trucks (and I have replaced more than my share).
you are right makes it very very clear!
