Engine removal pics
Old Oct 22, 2012 | 08:44 PM
  #646
2006lariat's Avatar
2006lariat
Originally Posted by run6.0run
Ok. Pistons. I'm gonna reference some things for us rookies, most of you already know
This piston came out of #2 cyl. #2 cyl is to the left. If you see how the rod cap bolts thread in vertical, and the rod goes to the left of the horizontal level of the cap bolt heads. Um, follow me???? I'm confused. Lol. So it's fairly easy to see how they were installed, as long as the cyl# is documented
One more rookie observation,,, do you see the triangles that are forged,(or whatever they are) on the rod caps? They point toward each other on their crank journal. It's a journal,,,, right?? That will reference how the cap was installed also.
Them V's are a extra bit of weight, used to "balance" the rod. (as good as they can be in a production forge environment.) If the rod is too heavy in the crank area they shave more material off. They also show the "top or Bottom", for reference for me to check hardness, or to measure how far they are bent.
Old Oct 22, 2012 | 08:45 PM
  #647
run6.0run's Avatar
run6.0run
Any pointers on the timing, or referencing it before I lift the crank out??
Old Oct 22, 2012 | 08:46 PM
  #648
run6.0run's Avatar
run6.0run
So does that mean that they don't have to point to each other,,,, in other engines I mean???
Old Oct 22, 2012 | 08:52 PM
  #649
2006lariat's Avatar
2006lariat
That is what it mean's. They are just extra weight. The bump's on the sides are "clamp pad's". They clamp (on these clamp pads) the rod's, hammer them with nitrogen, and break them. A lot of times they will have a different design on 1 side verses the other, so they know the proper way to orient the caps. Some may have the same numbers stamped on one side, so they can match the cap with the beam.
Old Oct 22, 2012 | 08:54 PM
  #650
m-chan68's Avatar
m-chan68
It's really too bad you are that far away. I literally have that tool sitting on my workbench UNUSED. But the way I read it, that tool only aligns the dowels on both cam and crank which both look relatively simple to do by eye. As far as I'm understanding it, if you turn the crank in a manner where that dowel is sitting perfectly at the 12 0'clock position and seeing where the cam dowel lines up, you should be good to go in my opinion.
Old Oct 22, 2012 | 09:05 PM
  #651
Rusty Axlerod's Avatar
Rusty Axlerod
Hey Anthony, are you marking stuff as you pull it? You can lightly center punch dots on the rods and caps where they separate and somewhere on the bottom of the piston. 2dots for cyl#2, 3dots for cyl#3 etc. to locate the orientation of the rod, cap, and piston, and it's location in the block. Number stamps are good also if you have some, but everybody has a center punch... Once they are marked like this you can put em in a cardboard box and shake it up and still know which one came out of what hole.
Old Oct 22, 2012 | 09:22 PM
  #652
run6.0run's Avatar
run6.0run
Very cool, I'm grabbing a bite to eat, then goin back down to check it out. It's ready to lift the crank out. Just wanted to follow up. It's a very critical part of this huh. I could ruin all the work if I screw that up. Don't wanna do that.
Old Oct 22, 2012 | 09:25 PM
  #653
run6.0run's Avatar
run6.0run
I have everything, I mean everything, in ziplock bags labeled with a sharpie. It has been working sofar,,, except for the adapter flange that I destroyed my garage looking for,,,,, hehe. Lol.
Old Oct 22, 2012 | 09:32 PM
  #654
run6.0run's Avatar
run6.0run
I wonder if I could make a tool before I remove the crank. The crank has a dowel, and I think the cam has holes. I'm goin back downstairs n a bit
Old Oct 22, 2012 | 09:39 PM
  #655
run6.0run's Avatar
run6.0run
I've gotta get the cam in the mail tomorrow. No matter what
Old Oct 22, 2012 | 09:58 PM
  #656
run6.0run's Avatar
run6.0run
Ok. I'm looking for a dowel or drill bit to put in backwards in the only hole in the cam pulley. There's a hole in the block also
Old Oct 22, 2012 | 09:59 PM
  #657
run6.0run's Avatar
run6.0run
15/64 fits in. It lets the cam spin a bit, but I think it would be easy to find the center of the slack
Now to place the crank, or find something to reference it
Old Oct 22, 2012 | 10:07 PM
  #658
run6.0run's Avatar
run6.0run
I'm gonna video the slack compared to the crank position sensor gear(I think that is what this is). If I insert the drill bit in the cam gear, then spin the crank clockwise (while standing at the back of engine), to take the slack out if the drill bit. This is what it looks like at the front of the crank
Old Oct 22, 2012 | 10:14 PM
  #659
run6.0run's Avatar
run6.0run
Here's a reference video. The crank was spun clockwise, which spun the cam counterclockwise. Red solo cup. Lol
http://youtu.be/99DHKlka46o
Old Oct 22, 2012 | 10:21 PM
  #660
run6.0run's Avatar
run6.0run
It works. If I'm a tooth off on the crank, it's way easy to tell the difference off of my reference pic
