Engine removal pics
Old Oct 22, 2012 | 04:26 PM
  #616
m-chan68's Avatar
m-chan68
So Anthony, what's the current status of your operation? Are you proceeding with your engine install as planned or what? And as far as the lifters are concerned, you do remember the part number I gave you to buy four in a set with the plastic guide, RIGHT?
Old Oct 22, 2012 | 04:29 PM
  #617
npccpartsman's Avatar
npccpartsman
PM it to me Mike so I can add it to my parts list, please?
Old Oct 22, 2012 | 05:45 PM
  #618
run6.0run's Avatar
run6.0run
I have just left the dealer. The kit with 4 lifters is a no brainier huh.
Old Oct 22, 2012 | 05:46 PM
  #619
run6.0run's Avatar
run6.0run
Took the block for a drive today. Shopping around for a machine shop
Old Oct 22, 2012 | 05:48 PM
  #620
run6.0run's Avatar
run6.0run
I've managed to get one of these
8C3Z-6C329B on the lifter kit???
Old Oct 22, 2012 | 05:50 PM
  #621
run6.0run's Avatar
run6.0run
I've got a question on the overhaul kit. The description says "and much more". Funny.
On this pic,,, from the top center, the pistons, locking pins, wrist pins, then are the next parts????? Valve guides???
Old Oct 22, 2012 | 05:52 PM
  #622
run6.0run's Avatar
run6.0run
Until it gets resolved, I'm on hold. But I can use my holding time to go ahead and rebuild the old engine.
Old Oct 22, 2012 | 06:00 PM
  #623
run6.0run's Avatar
run6.0run
I'm getting the overhaul kit... The machine shop will use whatever they can out of it, that way I get the full kit and don't waste money. I'm trying to find out what parts to tell them not to order,,,, looks like pistons, crank n cam bearings. Are rod bearings included? Anything included in the kit for the heads?
Old Oct 22, 2012 | 06:03 PM
  #624
run6.0run's Avatar
run6.0run
Here's another pic of it
Old Oct 22, 2012 | 06:04 PM
  #625
run6.0run's Avatar
run6.0run
Also, is the kit not available in standard bore size???
Old Oct 22, 2012 | 06:06 PM
  #626
strokin83's Avatar
strokin83
Prob not. Most people bore .20 off.
Old Oct 22, 2012 | 06:16 PM
  #627
run6.0run's Avatar
run6.0run
Overhaul kit, 16 lifters w plastic pieces,16 pushrods,16 valve bridges, $2690.33 tax included
If I do all rockers, all valves, and valve springs. It's $1102.18 extra, tax included
Old Oct 22, 2012 | 06:21 PM
  #628
strokin83's Avatar
strokin83
Does that overhaul kit include the complete gasket kit? If so that's pretty good for what your getting.
Old Oct 22, 2012 | 06:27 PM
  #629
run6.0run's Avatar
run6.0run
Thought this pic was interesting. It's complicated
Old Oct 22, 2012 | 06:29 PM
  #630
run6.0run's Avatar
run6.0run
Ok. Back to work.
Anything special to do before removing pistons? Can I remove the bed plate first?
