Engine removal pics
Old Oct 22, 2012 | 06:30 PM
  #631
run6.0run's Avatar
run6.0run
Originally Posted by strokin83
Does that overhaul kit include the complete gasket kit? If so that's pretty good for what your getting.
I'm thinking it does, the pic shows a bunch of stuff. Sensors also.
Old Oct 22, 2012 | 06:33 PM
  #632
strokin83's Avatar
strokin83
Nice. That's gonna be a tight booger when your done.
Old Oct 22, 2012 | 06:41 PM
  #633
run6.0run's Avatar
run6.0run
Prob not. Most people bore .20 off.
That sux. They have 10 over kits. It's $35 a cylinder to bore it. He said he'd have to measure it to see if I can get away without boring. That would b a cool $280 in my pocket. Then I could possibly rebuild 3 more times in the future. Don't you have to trash the block if the cylinders are messed up and ur at 30 over?
Old Oct 22, 2012 | 06:49 PM
  #634
run6.0run's Avatar
run6.0run
Here we go
Bed plate bolts out
Old Oct 22, 2012 | 06:51 PM
  #635
strokin83's Avatar
strokin83
I think it depends on the engine and how much meat they have between the cylinders. I think it's a good idea to bore that way you know your tight from the get go. But I'm not expert builder. I'm sure by now your looking to save every dime you can. I know what it's like to get in the middle of a big project and start swiping the card like a madman.
Old Oct 22, 2012 | 07:15 PM
  #636
run6.0run's Avatar
run6.0run
I'm really in now
Old Oct 22, 2012 | 07:21 PM
  #637
run6.0run's Avatar
run6.0run
Here's my crank bearings
http://youtu.be/pX2PWJog-fU
Old Oct 22, 2012 | 07:24 PM
  #638
run6.0run's Avatar
run6.0run
Here's my #8 piston
http://youtu.be/tARGrfaL_Y4
Old Oct 22, 2012 | 07:29 PM
  #639
MisterCMK's Avatar
MisterCMK
Looking good!
Old Oct 22, 2012 | 08:20 PM
  #640
m-chan68's Avatar
m-chan68
Originally Posted by run6.0run
You probably wouldn't believe it if I were to tell I have a 2011 E-350 5.4L right now in my bay all apart with only 12,000 miles that spun three rod bearings and one main bearing. The teflon coating on those pistons don't even look as good as your #8 piston!!!
Old Oct 22, 2012 | 08:28 PM
  #641
run6.0run's Avatar
run6.0run
Now on to the rest of the pistons.
Question,,, is the timing tool the only way to get it right?
Old Oct 22, 2012 | 08:31 PM
  #642
run6.0run's Avatar
run6.0run
Wow!!!!! Good news for me huh. Anyone need some "slightly used" pistons? Lol
Old Oct 22, 2012 | 08:39 PM
  #643
run6.0run's Avatar
run6.0run
Ok. Pistons. I'm gonna reference some things for us rookies, most of you already know
This piston came out of #2 cyl. #2 cyl is to the left. If you see how the rod cap bolts thread in vertical, and the rod goes to the left of the horizontal level of the cap bolt heads. Um, follow me???? I'm confused. Lol. So it's fairly easy to see how they were installed, as long as the cyl# is documented
One more rookie observation,,, do you see the triangles that are forged,(or whatever they are) on the rod caps? They point toward each other on their crank journal. It's a journal,,,, right?? That will reference how the cap was installed also.
Old Oct 22, 2012 | 08:41 PM
  #644
run6.0run's Avatar
run6.0run
Check out this rod bearing. It's the worst one
Here's the journal,,, I can feel a little groove with my fingernail.
Old Oct 22, 2012 | 08:43 PM
  #645
run6.0run's Avatar
run6.0run
1gal ziplock bags work
Here's my block. It turns over very easy now.
