Engine removal pics
Old Oct 19, 2012 | 10:25 PM
  #556
run6.0run's Avatar
run6.0run
New flywheel
Old flywheel
Old Oct 19, 2012 | 10:29 PM
  #557
run6.0run's Avatar
run6.0run
Originally Posted by nylyon
Is there a way to measure the depth of the dirt in the guide pin hole in the old flywheel? That dust cover seems pretty substantial and maybe you can measure the how far the pin went in on the old flywheel to see if it is missing or not? Just thinking here for ya?
Yeah. Good idea
Old Oct 19, 2012 | 10:30 PM
  #558
m-chan68's Avatar
m-chan68
Originally Posted by Yahiko
M-chan,
If someone had already been in there and worked on the flywheel & clutch
could they of left this part out or used an aftermarket flywheel that
does not have the shied?
Sean
You know Sean, that's a very good question. Quite honestly right now, I feel like a dink. I feel like I'm holding poor Anthony up from making any forward progress, but at the same time, I'm also trying to help him address a seemingly little, but at the same time very important detail. I don't want him going back together only to do damage over a detail like this.
At this point, part of me is beginning to believe that part wasn't there before, when looking through the pics. What I've been beating my head up about, is the last time I was ever into a manual transmission equipped 6.0L. Unfortunately, there are very few of them out there.
Old Oct 19, 2012 | 10:38 PM
  #559
run6.0run's Avatar
run6.0run
Here is a pic of the guide pin hole
I used a paper clip to compare the depth of the scratches to the length of the dowel
Old Oct 19, 2012 | 10:42 PM
  #560
run6.0run's Avatar
run6.0run
I'm on the phone with Sean now ( and have been with the past few posts). My phone lets me talk and surf. Whu hu. It looks like the rear crank seal was rubbing on the flywheel. Not holding me up at all!!!!! I appreciate all input.
  #561
run6.0run's Avatar
run6.0run
They are very close.
Old Oct 19, 2012 | 10:43 PM
  #562
nylyon's Avatar
nylyon
And the dowel likely has a tapered end, so you have to account for that.
Old Oct 19, 2012 | 10:45 PM
  #563
nylyon's Avatar
nylyon
I've never been in the bottom end of the engine so I am completely out of school here. The flywheel seems to have a lip similar to the dust plate. So in essence, the flywheel could also serve as the dust plate, and if that is the case, the dust plate is a spacer which *should* be irrelevant since the input shaft of the trans is going to enter the crank regardless, and as long as the splines run deep enough, shouldn't matter, spacer wise anyway.
BTW, this WOULD matter for an automatic.
Old Oct 19, 2012 | 10:46 PM
  #564
m-chan68's Avatar
m-chan68
I must be the craziest Chinaman you guys will ever meet (but likely never shake hands with).
Anthony, look at your old flywheel mounting hole mating surface closely. Now have a look at the rear flange of your old crankshaft. Do you see a unique imprint on both sides that make it evident that the two were mated together without anything in between? If so, it looks like you never removed that piece to begin with.
Old Oct 19, 2012 | 10:54 PM
  #565
m-chan68's Avatar
m-chan68
Karl, the portion of your statement highlighted in bold red is where you are incorrect. On these engines in particular, did you not notice that the pilot bearing for the input shaft is pressed into the FLYWHEEL, NOT THE CRANKSHAFT?
I was almost going to suggest Anthony temporarily bolt up the flywheel onto the crank and temporarily bolt up the starter to the rear cover, and slide the starter gear out fully, just to see how the gear aligns with the ring gear on the flywheel. And if the gears fully mesh properly, then I guess it's good to go. But that seems like a lot of work too.
  #566
Yahiko's Avatar
Yahiko
M-chan,
Should there be location dowels on the flywheel for the cover?
I don't see any in the photos.
Sean
Old Oct 19, 2012 | 10:56 PM
  #567
nylyon's Avatar
nylyon
Crap, forgot about the starter! BUT if he mounted the old flywheel and checked the wear pattern on the starter that would likely give the answer. (and not as much work as finding the part AFTER everything is together)
Old Oct 19, 2012 | 11:00 PM
  #568
m-chan68's Avatar
m-chan68
M-chan,
Sean
Of course there is. The dowel is what prevents the flywheel from being installed onto the crank other than the way it came off. Although I don't know on this particular engine, some engine applications use an external offset balance on the flywheel as well for this. The Chevy big block 454 comes to mind as an example.
Old Oct 19, 2012 | 11:03 PM
  #569
run6.0run's Avatar
run6.0run
Here us my crank. Check out the discolor at the tip of the screwdriver
Compared to this
Old Oct 19, 2012 | 11:09 PM
  #570
Yahiko's Avatar
Yahiko
The reason for the question is I don't see any pins on the face of the flywheel
for the clutch cover to locate on. Do they need to be there ?
Sean
