Engine removal pics
Old Oct 9, 2012 | 09:38 PM
  #106
m-chan68's Avatar
m-chan68
Originally Posted by run6.0run
My valve bridges have scratches also
That is completely normal with the valve bridges being like that.
Old Oct 9, 2012 | 09:40 PM
  #107
run6.0run's Avatar
run6.0run
I found it easy to remove the rocker arms then let the pushrods drain while removing the other side. Them things will drain for a while.
Old Oct 9, 2012 | 09:46 PM
  #108
run6.0run's Avatar
run6.0run
Here's my rocker arms. I should be replacing these right?
I mean I'm gonna do lifters, should the valve train be replaced also?
Crap, my pics got all scrambled somehow. Well, I'm gonna just post them. Not necessarily in order.
Old Oct 9, 2012 | 09:47 PM
  #109
m-chan68's Avatar
m-chan68
Just to let you know, I have been very curiously keeping an eye on this thread, even if I haven't posted much. What I am noticing with great interest is you appear to have the late '06 version of this engine, which is the latest and most updated possible version. This means your cylinder heads from Ford will be part number 6C3Z-6049-AA should you need to replace them, not 3C3Z-6049-DA for 2003 to early '06 engines. This also means your engine uses 20mm cylinder head dowels on the block as well as the heads.
I am extremely curious to see if the replacement engine is in fact going to come with the correct rear engine cover installed on it that is unique to manual transmission applications.
Old Oct 9, 2012 | 09:50 PM
  #110
run6.0run's Avatar
run6.0run
Trying to keep the injectors alive. Dipped them in oil, then bagged them up.
Here is a great example of why care needs to be taken when seating injectors. I screwed two of em up. And ran em for a long time. I'm not too proud, if I focus on my screwups, hopefully I will learn from them.
Old Oct 9, 2012 | 09:51 PM
  #111
m-chan68's Avatar
m-chan68
Pay particular attention to the condition of the rocker arm tip ball pivots. Is there excessive play as you pivot them? If not, I would only replace all the black plastic fulcrums. They are pretty cheesy in my opinion. It's too bad the metal accordion spring type fulcrums used on earlier engines are now obsolete.
Old Oct 9, 2012 | 09:52 PM
  #112
run6.0run's Avatar
run6.0run
19 mm socket works great.
I think this injector has 582k on it. Dang!!!
Old Oct 9, 2012 | 09:54 PM
  #113
run6.0run's Avatar
run6.0run
Thought I would try it
It lays down in shame. Lol
This outta do it
Old Oct 9, 2012 | 09:58 PM
  #114
run6.0run's Avatar
run6.0run
Oh man, no they move like bobble heads.
Old Oct 9, 2012 | 10:00 PM
  #115
run6.0run's Avatar
run6.0run
Rocker boxes off
Old Oct 9, 2012 | 10:03 PM
  #116
run6.0run's Avatar
run6.0run
Ok here it is. Is it just me, or do these look blown
This is the even side, previous was odd
Old Oct 9, 2012 | 10:07 PM
  #117
run6.0run's Avatar
run6.0run
Aren't the star patterns and burn marks tale tell signs of adding power above stock. Or does stock mark up the pistons too?
Also are those hone marks?
Old Oct 9, 2012 | 10:08 PM
  #118
run6.0run's Avatar
run6.0run
Kinda represents my world right now. Lol
Old Oct 9, 2012 | 10:09 PM
  #119
m-chan68's Avatar
m-chan68
You're going to absolutely HATE me. NONE, and I mean virtually NONE of the cylinder firing rings looked breached at all on all eight cylinders. This thread should be a perfect testament to how long have head studs and OEM Ford gaskets can make these engines run for. They actually look to be in PERFECT condition.
Old Oct 9, 2012 | 10:12 PM
  #120
run6.0run's Avatar
run6.0run
Ok I'm in uncharted territory now. This is under the oil pan.
