- 360 intake swap
- Where is it???
- Where did all this oil pressure come from?
- 390 build up ?
- 390 crank in a 360, what compression?
- 390 rocker arms again
- C-6/390/460 Compatability
- fe heads
- 2 vacuum port distributor question ?
- need a 427 block
- 360 inspection
- looking at buying a 69; is a 360 good...
- FE in a '79?
- HP / Torque of a 360???
- smoking grounds
- FE Rockers
- Exhaust Manifold Bolts
- power from mild uprgade
- Specs needed
- 427 carb question
- 9:1 Pistons???
- 360 or 390???
- 71 360 fuel pump eccentric
- Gears
- Head Gaskets
- Machining question,cam installation
- 1974 390
- cam specs.
- 390 hesitating bad
- is 4.090 a safe bore size?
