360 intake swap
Old Mar 22, 2003 | 10:06 AM
73tank's Avatar
73tank
360 intake swap
Hello all.
I'm looking for opinions/experince with changing the 360's intake to a 4bbl using a ford (boneyard) 4v intake. I already have a rebuilt holley to slap on. I've read the posts re: not much gain etc., but I want to get a little more out of my motor without dropping serious coin. Seeing that I already have the carb, and the local boneyards are cheap...ish, I thought thius would be a good low dollar improvement. Any reactions / "been there done that" ?
ps: truck is basically stock other than dual exhaust. Not used for towing, just tooling around cattle ranch.
thanks
Old Mar 22, 2003 | 05:19 PM
jowilker's Avatar
jowilker
360 intake swap
If ya gotta do this thang, look for an intake with the S on it. You would be better off adding Pertronix to the ign. system. IMHO
Old Mar 23, 2003 | 07:03 PM
67 428 Fairlane Ranchero's Avatar
360 intake swap
Ther are only a few reasons that I usually change from a two bl to a four bl and power is not always the best reason. For the FE probably the best reason is because ot the weight factor, if the weight matters to you, another reason is to upgrade the carb and I personally have not had any good luck using a <a href="http://motorhaven.autoanything.com/">Holley</a> unless you like to adjust it all the time, it was probably not set up for you specific engine, another reason is the electric choke upgrade here in Montana the weather is always changing and a good choke is very important. And like jowilker says put a Pertronix on it would help alot. Sometimes changing intakes you can create more problems than you solve.
maytag906
Aug 29, 2016 09:28 PM
ri_truck_guy
Jun 21, 2012 03:50 PM
PeeWeeRacer
Jan 13, 2010 11:09 PM
fordfaninIL.
Sep 14, 2006 08:39 PM
Annihilator
Jan 21, 2005 05:09 PM
