- 10 MPG. Woohoo!
- hard start
- 428 crank in a 390?
- is this cam any good
- HELP!! Motor runs horribly after carb rebuild....
- Inexpensive rockers arms?
- Windage trays?
- water in the crankcase
- carb problem
- Sitting 360
- 428 valves in 390 heads
- Max. bore for a 360 FE
- 352 vs 360
- 360 Upgrade Questions
- Tq and hp specks for 352 ?
- solid lift adj.
- cam spacer
- 390 oil clearance check
- cam end play and core plug
- 360 bored .30 over
- Rotella 5W40 Full Synthetic in an FE
- restarting a 360 that has been sitting
- What hyd. flat tappet lifters do you guys prefer/recommend?
- Distributor change?????
- 427: unbalanced flywheel
- 390 Crank needed
- 390 with rattle under acceleration
- 4-spd. toploader to FE, guys please read...
- Ford 390 Headers.
- valve noise
