Ford 390 Headers.
Old Dec 13, 2004 | 06:20 PM
galaxie64's Avatar
galaxie64
Question Ford 390 Headers.
I have a 390 engine with the cast iron shorty headers. These were stock units used on early FE engines. Would a set of Tube type headers ( Hookers )
give me more H/P and would it be worth time and money.
Thank You
Martin.
Old Dec 13, 2004 | 08:22 PM
rusty70f100's Avatar
rusty70f100
Yes, and you could probably sell those shorty cast headers and come out ahead in performance and money!
Old Dec 13, 2004 | 10:02 PM
tukes48's Avatar
tukes48
just make sure u watch the heat on the starter from the the headers
Old Dec 15, 2004 | 06:13 PM
bertha66's Avatar
bertha66
Your shorty cast headers, are they the 406/427 stock headers? If you are working on a 64 Galaxie, check the new headers to see if the power steering will clear, some will not. Not alot of room around the headers on the 64's. I have had mine for 32 years.
Old Dec 15, 2004 | 07:49 PM
galaxie64's Avatar
galaxie64
Hello; Yes these are the short style use in the early 60's Cast iron. I will use a set, made out in Cal. They make headers and other parts just for FE blocks and for the 64 Galaxie.
Thank You
Martin.
Old Dec 17, 2004 | 04:44 PM
bertha66's Avatar
bertha66
Those cast iron headers command a big price. The headers should work great. The 390 will breath better with headers. Myself I run the stock manifolds with SS pipes and SS Megaflow muflers that exit infront of the real wheels.
Old Dec 17, 2004 | 08:18 PM
Steve A's Avatar
Steve A
Question:
I would presume that the cast-iron Ford headers (which my 390 has) would be inferior to performance headers. Why would cast-iron headers command a big price ?
Old Dec 17, 2004 | 11:16 PM
thunderguns71's Avatar
thunderguns71
They are a rare item that was mostly found on factory 406's and 427's. Might have been other factory HiPo Fe's. Don't really remember. People will give a pretty $ amount if they have an HiPo engine that came factory with them or in some cases they are easier to make fit than an aftermarket header. Like a set of Super Comps for a 64 Galaxie is around 450$ or a lil more and have to be slightly modified. For about 50$ more you can get a decent set of cast irons and it would fit perfect and still have a pretty good performance increase. Plus they look cool
greentruck72
19
Dec 6, 2016 11:40 AM
Cody360-390
Nov 14, 2014 06:38 AM
MR-HI-BOY
Dec 10, 2010 11:23 AM
mooray
Exhaust Systems
Aug 29, 2010 02:04 PM
BrettCox
Aug 30, 2002 11:21 AM
