427: unbalanced flywheel
Old Dec 14, 2004 | 10:54 AM
Power_age's Avatar
Power_age
People: I have a friend who has a 427. the engine havn´t flywheel(for clutch)
he need to build a disc, but we now that these engine have the flywheel unbalanced. anyone can tell me some about this thing? or some web page where I can find some info.
Regards,
Mariano
Old Dec 14, 2004 | 11:08 AM
Bear 45/70's Avatar
Bear 45/70
The flywheel all FE engines except the 428 are internally balanced. That means the flywheel is balanced by itself as is the crank (there is room for the counter balancing inside the block) . The 428 didn't have enough room to balance the crank inside the block and some of the counter balance weights are on the flywheel, otherwise it matters how the flywheel lines up on the crank. If that flywheel isn't balanced on it's own it's a 428 flywheel and don't use it.
Old Dec 14, 2004 | 11:23 AM
Power_age's Avatar
Power_age
Bear 45/70: thanks so much for your answer, this guy have the engine stopped for a months by don´t know this information.
regards,
Mariano
Old Dec 14, 2004 | 12:08 PM
Bear 45/70's Avatar
Bear 45/70
I used to race 390, 427 and 428CJ's back when they were all there was for a big block Ford guy to run. After building a few you learn what is and what isn't. Of cousre I have a lot of reference books to help the old memory and I did look this up to confirm it.
Old Dec 14, 2004 | 02:31 PM
Freightrain's Avatar
Freightrain
I bought a 428 back in the 80's that happened to have a std 390 wheel on it. Boy, could not figure out the shake...LOL!! Til I researched a bit and found out the reason. Once I got a true 428 wheel, it was smooth as glass.
Now all my 428's get neutral balanced so that flywheel changes are simple.
19
Nov 16, 2016 03:12 PM
Russell34
21
Aug 25, 2016 03:25 PM
DrZoom
16
Sep 16, 2015 02:11 PM
ColoradoFordBoys
Aug 14, 2014 11:12 PM
rick
Jun 21, 1999 07:29 PM
