- who has the most powerfull 390
- 352 Lifter noise
- Valve spring removing tools
- Oil Pan Leaking
- What is are the specs and stats for the 390 FE in 1976
- Need some help/advice
- Lack of oil pressure
- fearing the worst.
- dual carbs on a 360?
- '77 330 hesitation problems solved?
- 390 piston rod retainer clips broke!
- 360 & 361
- 390 Stroker
- Comp's new Beehive Valvesprings available for FE's yet?
- C3 or C1/C4 heads
- Carb and manifold reccomendations
- oil dipstick level on 352 ?
- 360 engine flush!
- Found a 390 for my 70'
- ? about timing gear to cam dowel
- knock diagnosis
- Stay with 3.50's or go to 3.25's?
- The tuning has me confused
- my 390
- UH OH... Blue smoke
- Alternator Mounting
- won't start
- Stuck distributor
- Steering wheels
- need speed for my 60 tbird
