Valve spring removing tools
Old Mar 24, 2005 | 08:26 AM
Edge Motorsport's Avatar
Edge Motorsport
Guys,
what type of valve spring removing tool do I need to pull the springs on a 360 FE.
I dont want to take the heads off to do it and Ive seen a bunch of tools at summit but they all use the rocker stud for leverage, and all out rockers are on a single bar ....
anyone got any wise ideas ???
EDGE
Old Mar 24, 2005 | 09:35 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Originally Posted by Edge Motorsport
Guys,
EDGE
Make it Easy on yourself....I have a compressed air spring tool,that hooks to my compressor....Just pull the heads....Other wise your going to have to buy a Air Adaptor, that screws into the Spark plug hole to put pressure on the Valve's to keep from dropping them into the Cylinder!! And still need a Air spring tool to do the job.. And while the Heads are off you can bowl blend them and Port match too!! Then go with a bigger cam!! LOL!!
Russ
Old Mar 24, 2005 | 12:24 PM
Edge Motorsport
but dude... pulling the heads is a PITA and ive already got the spark plug hole adapter for the air line.... whats this air spring tool ?????
damnit... this is getting really expensive.... now i need another set of head gaskets.....
EDGE
Old Mar 24, 2005 | 02:14 PM
RapidRuss's Avatar
RapidRuss
Awwwww!!! Life aint cheap when your talking Performance!!!! A Valve spring air compressor...is about $30..there not that bad....And Before you use the spring compressor...use a dead blow or a rubber mallet..and smack the top of the Valve springs in the center once or twice to loosen up the keepers from the Valve stems!!
It save from trying to pick them away from the stem once you have compressed the Valve!!
Good Luck!!
Russ
Old Mar 24, 2005 | 04:41 PM
66f100352's Avatar
66f100352
Funny I literally just finished this job myself 2 days ago here's what I did remove spark plugs crank engine by hand till piston was TDC then crammed with rope held everything in place nicly but it was time consuming. As for the tool I got one at Autozone for 15 bucks looks like a claw but it is a pieace of sh** but it did get the job done. Anyhow good luck and just relax and take your time.
Old Mar 24, 2005 | 05:29 PM
Edge Motorsport
cheers guys...
looking at summits page tehy dont seem to have one like you described, guess I'll have to call them....
EDGE
Old Mar 24, 2005 | 09:51 PM
66f100352's Avatar
66f100352
The Autozone tool is brand OEM part number 25220 like I said it's junk but it was only 15 bucks and they do rent it as well..it did get the job done.
Old Mar 25, 2005 | 08:42 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Russ what spring compressor did you buy? $30 is pretty good and will it work on the dual springs w/dampner? I've tried the store bought POS ones but no good for dual springs. Other than spending $150+ on a good one the air tool sounds like the way to go. Thanks, G.
Old Mar 25, 2005 | 10:04 AM
fordeverpower's Avatar
fordeverpower
The claw type are junk! Sears sells a $20 c clamp thats works great on mild springs. As for dual springs I am still looking and i plan on $150 for one too. I would really like to get the ones that plug into the air compressor cause they are slick as crap.
Old Mar 25, 2005 | 11:18 AM
RapidRuss's Avatar
RapidRuss
Check around some local garage's or some Mechanics at Dealers..possibly get a used one from them??
I got mine about a year ago..wasnt even looking for one..stoped at a pawn shop looking at there guns.....Saw the Air powered Valve spring compressor and A 1/2 drive Snap-on Torque Wrench,and a 1/2" drive S/K Air Impact..All for $100
Russ
Old Mar 25, 2005 | 11:39 AM
fairlaniac's Avatar
fairlaniac
I've used this kind
[IMG][/IMG]
I use an old rocker shaft and stands without the rockers and springs. You could just remove the rockers and springs in the area that you're working in. I attach the shaft and hook the hooks over the shaft, align the foot end of the compressor on top of the valve retainer and press, remove the locks and retainer and you're there. Of course you used the air line in the spark plug hole to hold the valve.
Old Mar 25, 2005 | 11:42 AM
fairlaniac's Avatar
fairlaniac
You're in the UK?
Here is a place that sells the above shown spring compressor http://www.fine-tools.co.uk/Merchant.../ns-yf6225.jpg
MONAVIERONJON
Aug 30, 2012 01:23 AM
Rivergreen74
May 8, 2012 10:23 PM
78BigBlock09
May 5, 2010 06:50 AM
oldmansimek
Apr 12, 2006 10:53 AM
90f150moneypit
Aug 26, 2003 06:22 PM
