- I'm still alive!
- What about the Transmission?
- Is my idle oil pressure too low?
- FE Engines Rebuild Questions
- Shudders, shakes in drive
- cam install trix
- Good discussion Beemer Nut
- piston material differences ?
- 390 timing question.....please help
- Supercharged 390 for low end torque
- Push Rods Are Worn to A Point
- 428 CJ intake, 410 CID, for 3/4 ton 4x4
- o/t intake mods (horsepowerwise)
- Lemans rods
- FE sound clips
- 1966 390 GT build
- new paint dekal
- Maxtron DEO diesel oil
- 390 w/Serious Knock Under Load
- cam advice please
- Intake Manifold Gasket - 360/390
- carburator linkage diagram?
- 360 top end
- General Engine Rebuild ?
- Thrust bearing surface alignment
- FE blasts around Kansas Speedway
- Fix for oil pan dipstick leak
- New head bolts
- Please verify my block casting numbers
- cam bolt and washer?
