Please verify my block casting numbers
Old Sep 6, 2006 | 05:05 PM
stricky's Avatar
stricky
The block on my '67 390 GT Mustang has the following casting numbers. (I think as some numbers are hard to read).
Block # C6ME-
Date code: 5F11
Do these numbers look right? A '66 block cast in '65?
Thanks
Anthony
Old Sep 6, 2006 | 05:52 PM
Bear 45/70's Avatar
Bear 45/70
The 1966 model year starts is late 1965 around September, so yeah the numbers work.
Old Sep 6, 2006 | 08:10 PM
stricky's Avatar
stricky
But the casting date "5F11" means June 11th '65...
Old Sep 7, 2006 | 05:35 PM
Bear 45/70's Avatar
Bear 45/70
I know what it means. Have you any idea of the lead time required for the new model year? Hell, this years model is barely released when all the effort turns to the next model year.
Old Sep 8, 2006 | 10:02 PM
gier-head's Avatar
gier-head
What are the other casting dates on the other engine components? Are the within the right dates for your 67 GT? Is there an assembly date stamping on the bare block somewhere? I forget where they did put these on the FE series. Small blocks had them in front of LH cylinder head on a little "ear". This date is when the engine was assembled. If you can find this, it would clarify whether engine is original or not. With a 5F11 date, that seems rather early for a 67 model. Unless it has been replaced by a previous owner or a Ford garage at some point. ??
Old Sep 9, 2006 | 08:28 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
There are also fimished machine dates stamped into the block. There are 2 "ears" that stick out on each side of the block right by the head deck. You'll find the finished machine dtae stamped into the flat vertical face of the left (dr side) one. You'll have to scrape away the paint to read them. They also follow the same format the date codes have as far as decoding them. Either way it might be a bit early for a 67 car. As advised check the other date codes on the heads, intake etc... to see how they match.
G.
pit_of_pity
Apr 14, 2011 06:48 AM
jacob_9249
Jul 26, 2008 08:04 AM
58Model
Nov 14, 2002 02:30 PM
plowd1
Sep 2, 2002 05:38 PM
bigf150
Apr 5, 2001 08:23 PM
