- Heavy duty tire removal. How much torque? Psi?
- Air intrusion Sticky
- 6.9 grey smoke won't go past 2500 rpm
- Trying to ID transfer case...yoke doesn't match what I expected..
- tURBO SMOKES when STARTED COLD ?
- need advice on getting my idi road worthy again
- Fuel pump help!
- Weirdness when I started the IDI today.
- Diesels for Dummies? First diesel...
- 460 into 7.3
- FINISHED COOLANT FILTER AND E FUEL PUMP
- Sheet metal piece below grille on a 93?
- coolant hose routing questions
- Zf swap
- This might help someone: truck idles as if misfire but doesn't smoke/smell
- How much clatter is too much?
- new turbo and injectors
- Oil Leaks and Blue Smoke
- 7.3 heads on a 6.9 block?
- 6.9 need more power! (Duh)
- No Reverse
- HeLp!!! Urgent!!! Clutch matters
- 6.9 intake
- injector cap blowing fuel
- Troubleshooting fuel issue / Truck has a mind of it's own...
- To keep or NOT to keep... That is the question...
- coolant filter question. galvanized fitting ok?
- Well that was fun. (Getting a busted brass bushing out of my cylinder head)
- I've had it! holly fuel pump coming. question about plumbing
- Zf5 rebuild manual
