injector cap blowing fuel
I have a 1987 F250 with a 6.9 N/A Diesel. Yesterday i was driving and smelled fuel. I found the front injector was blowing fuel out of the cap next to the injector line. I didn't know what was wrong so i replaced the injector thinking the injector was blocked but with the new injector it still is blowing fuel between the line and the cap straite up. Any ideas?
By blowing straight up do you mean around the fuel line through the hole in the fitting? If so I would start with the line. If it's coming out below the fitting then o rings would be my first guess. I'd say if you have to replace the o rings on one injector then do them all while you're at it. If not you might be doing it again 7 more times
Wreckers.towing
05-23-2015 11:25 PM
1991 F Super Duty
16
06-30-2013 08:07 AM
Scott-F350
08-16-2004 12:43 AM
