Stock intake
Old Sep 6, 2002 | 05:08 PM
mudkat66's Avatar
mudkat66
Stock intake
What am i losing using the stock intake over the weiand stealth with a Edelbrock 750cfm on a future build up.
Thanks
MudKat66
Old Sep 7, 2002 | 11:17 AM
one bd ford's Avatar
one bd ford
Stock intake
it all depends on your cam if the rpm ranges match the stock intake. if they do not match you will not get the full power gains but if it is all closw it will be fine. the weind stelth and the 750 carb as you may no is a good combo for the 460 the stealth has good operating rpm ranges which is close to stock on the low end side but has a higher upper rpm operating which is good for a lager cam. i hope i made some scine in my rambling
Old Sep 7, 2002 | 09:07 PM
georgedavila's Avatar
georgedavila
Stock intake
Up to 3500rpm, there's no difference between a stocker and any of the aftermarket intakes. What rpms do you planing on running?
Old Sep 8, 2002 | 12:58 PM
85351ho's Avatar
85351ho
Stock intake
aluminim intakes are prettier and about 40-50 lbs lighter
Old Sep 9, 2002 | 08:37 AM
mudkat66's Avatar
mudkat66
Stock intake
I'm not really sure about the rpm's. It's goning into E-350 van and will be used for towing a boat or a camper. I guess what I'm looking for is mainly torque.
Old Sep 9, 2002 | 08:46 AM
georgedavila
Stock intake
I'd go with an Edelbrock Performer, not the RPM. Just to avoid dealing with the cast iron manifold is worth $200.
Old Sep 9, 2002 | 03:15 PM
85351ho's Avatar
85351ho
Stock intake
