Vacuum
Old Sep 4, 2002 | 04:34 AM
4trax's Avatar
4trax
Vacuum
This is what edelbrock said to hook up what do you guys think? you'll have to read from the bottom to top as this was what was e-mailed back n fourth.
Drivers side.
-----Original Message-----
Sent: Tuesday, September 03, 2002 1:56 PM
To: cratetech
Subject: Re: carb?
Which is what side? Driver side or passenger side
----- Original Message -----
To: '4trax'
Sent: Tuesday, September 03, 2002 10:30 AM
Subject: RE: carb?
For performance most people use the full vacuum source.
Sent: Saturday, August 31, 2002 11:01 AM
To:
Subject: carb?
I have 750 edel. man. choke.I bought from you guys and was wondering which way to hook up the vac.Full advance vac. on the driver side of carb or hook it up to the other port the passenger side of carb. I want as much power and snap as I can off the line and up. It's on a 78 460 with goodies What are the pros and cons of each.Thank you
Old Sep 4, 2002 | 11:41 PM
phantom429's Avatar
phantom429
Vacuum
This is not a complicated thing. There is either ported or manifold vacuum available. Pick one, and stick the hose on it. I suggest ported.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old Sep 5, 2002 | 04:54 AM
4trax's Avatar
4trax
Vacuum
THE RIGHT VACUUM: One way among many to get into trouble when attatching all the various hose, cables and plug ends is to hook the vacuum advanve to the wrong vacuum source. If they want full advance at idle the vacuum mechanism must be hooked to full manifold vacuum, as found at any port below the carb throttle plates. Spark-ported vacuum comes from ports immediately above the throttle plates. It will supply vacuum spark advance as soon as you begin to open the throttle, but there is no advance at idle or at any other time when the throttle is closed. This was originally done to prevent detonation caused by lean emission mixtures and was later used for a variety of emissions functions such as EGR control.
Retarded timing can cause overheating, so make certain you are taking spark vacuum from the correct port for your application. An older non-emission vehicles or modded hi-po vehicles, full manifold vacuum will yield a smoother idle and better performance. On emission controled cars, you must use the spark-ported vacuum to remain legal and get the best possible performance. And if your car is equipped with a EGR, by all means leave it hooked up. By passing the EGR will cause yuor late model car to lose performance, not gain it. I found this and just thought I would post it for others who have old iron like me and want everything they can out of it.
PSYCHO 1977 F-250 4x4 472cid 4spd., PSYCHO2 19771/2 F-250 4x4 472cid.auto. Pulling Trucks/Race Trucks and goodies to go with them!!!,1987 Mustang GT 5.0 H.O. SNAKEY2. 1989 Mustang LX 5.0 H.O. Spectator Eliminator!
Not worried about gas mileage just performance!!!
Old Sep 15, 2002 | 04:40 PM
LxMan1's Avatar
LxMan1
Vacuum
The right port(drivers side) is maifold vacuum, the left is ported vacuum. I would try the left one first. That's the one I use on my 460 with an Edelbrock 750.
Old Sep 16, 2002 | 12:22 PM
dpoelstra's Avatar
dpoelstra
Vacuum
