Guys, My question has probably been answered but my searching skills must not be up to snuff. Anyway, I have a problem with my 352 running rich. Here's some background:
-original '66 352, carb, heat riser, etc
-carb was rebuilt a week ago
-I've checked for vacumn leaks in the usual places...no leaks.
-timing is correct
My situation: After having the carb rebuilt, I installed it and backed off one and a half turns, and tried to dial it in based on the RPM but the engine is running extremly rich. It idles best when the screws are screwed all the way in and even then it's rich. I beat on the carb for a while with the handle of hammer. I pulled the fuel filter and gave it a few shots of cleaner. I don't have a vacum gauge but am willing to buy one if that's the recommend course.
Secondly... Did you rebuild the carb or have it done by someone else? It sounds like you may need to drop the level on the floats. This will entail opening it up and bending the tang holding them. If you are not comfortable with this, contact who rebuilt the carb. Secondly, how is the idle, is it fast/slow? How have you determined it to "run rich"? A little more info and we'll move forward
I had the carb rebuilt by one of the better shops in town.
As far as the idle, it idles best when I have the adj. screws screwed all the way in. Then it idles with 50 - 100 rpm of where I set.
I determined it to be rich based on the smell, tears, and exhaust. The plugs reflect the same.
Is that the autolite / motorcraft carb? Those things ALWAYS blow out the power valve. One backfire and it's gone. And it does exactly what you're describing. Get a good rebuild kit for it and go to town.
if it was just rebuilt it shouldn't need a powervalve unless it had a nasty backfire. rusty is right though, if it did have a good backfire while trying to start it its your powervalve
It could be worse. It could be running poor! Okay bad joke! I agree with the above. It is either the power valve or the floats are set too high. If the jetting wasn't changed then that would be the only thing left. If your fuel pump is stock you need not worry about too much pressure.
...and if you are not comfortable with all this, I would contact the rebuild shop, describe what's going on and ask how they will be able to take care of your issues. I would do that before opening anything up too, if you spent some good money on the rebuild, it would be a shame to ruin any chance of "warranty" by cracking into it yourself.
thats true mike, if they rebuilt it they should make sure its going to run right. whats the sense of having the carb rebuilt if its not going to run good ! jmho
