one more problem to add heating?
Old Sep 11, 2013 | 07:57 AM
gomer450's Avatar
gomer450
we replaced thermostat, hoses water pump everything but rad
rad doesn't leak had it cleaned and said no problems with it
I put a elderbrock intake on it just wondering if intake gaskets are on back words or?
gomer450's Avatar
gomer450
oh its on a 351 w with a solid fan
Old Sep 11, 2013 | 08:16 AM
Gary Lewis's Avatar
Gary Lewis
You are going to have to tell us more. In both of your threads you appear to be asking for help without telling us the details. Your title on this one suggests you want to "add heating", but the words seem to indicate you have a heating problem. But there are no symptoms listed.
Please slow down and tell us what you have, what the symptoms are, under what conditions, etc. we cannot help if we don't know.
Old Sep 11, 2013 | 08:25 AM
gomer450's Avatar
gomer450
I put an hei distributor in the truck as well 4 brl holley carb with timing right on
the coolant gushes out tryin to get the air outta system by leaving cap on doesn't heat as quick as when caps on so hey thought must be cap got new rad cap as well
I shut truck down when reach's 120 degrees c
only thing making me second guess intake gaskets are screwed up
Old Sep 11, 2013 | 10:05 AM
Gary Lewis's Avatar
Gary Lewis
Ok, let's take this one statement at a time:
"I put an hei distributor in the truck as well 4 brl holley carb with timing right on"
  • You've replaced the intake manifold, so I'd guess you have a major vacuum leak as well as coolant leak. It is extremely easy to get the manifold on at a slight angle - I did it recently.
  • And, you've had the dizzy out and back in, so set the timing "right on". Right on to what? And, how do you know the harmonic balancer hasn't slipped? I had one that had a year ago and the marks were way off.
"the coolant gushes out tryin to get the air outta system by leaving cap on doesn't heat as quick as when caps on so hey thought must be cap got new rad cap as well"
  • Wow - I'm not sure what you said. But I'm going to guess that you are trying to get the air out of the system. Just pull the temp sender and fill it up until coolant runs out there. That gets most of the air out.
  • The cap has nothing to do with the length of time it takes to heat up.
"I shut truck down when reach's 120 degrees c " How do you know it hit 120 C? Are you using a thermometer of some type?
"only thing making me second guess intake gaskets are screwed up" I do not understand at all. Please explain.
brian klein
Feb 29, 2012 02:30 AM
broncoman72
1997 - 2003 F150
19
Nov 7, 2010 04:53 AM
Damomasts
1997 - 2003 F150
Nov 2, 2010 06:02 AM
EaTmYtAiLpIpEs
Nov 20, 2007 04:59 PM
jimhackney
Mar 16, 2007 08:04 AM
