front spring mount
Old Sep 11, 2013 | 07:23 AM
gomer450's Avatar
gomer450
front spring mount
need a front spring mount for frame does anyone know where I can find them?
lmc an blue oval only rear spring mounts
thanks
Old Sep 11, 2013 | 07:38 AM
truckertrav's Avatar
truckertrav
thanks
I will try to help..Need more info...
Year, model, 2wheel or 4 wheel drive,etc..
Old Sep 11, 2013 | 07:53 AM
gomer450's Avatar
gomer450
oh sorry
80-81 I think has the holy frame
4wheel drive
Old Sep 11, 2013 | 07:57 AM
garthneddy's Avatar
garthneddy
I picked up two spring towers straight from my local Ford dealer.
Old Sep 11, 2013 | 08:01 AM
gomer450's Avatar
gomer450
sorry forget to add f250 leaf spring hanger ford doesn't carry them
Old Sep 11, 2013 | 09:06 AM
truckertrav
I still need more info...
Is it 80 or 81....F250...4wd...dana 44 or 50 front axle..Do you need the mounts for the front or back of the front springs..etc...gross weight rating.
Left or right side or both....
ALL of this is critical to get the CORRECT parts..Thank you...
Old Sep 11, 2013 | 09:11 AM
gomer450's Avatar
gomer450
need left drivers side front rear there a huge mount
dana 44 but will be converting over to solid dana 60 when I come across one
dunno the weight rating the leafs are wore out will be buying lift for it
Old Sep 11, 2013 | 09:54 AM
truckertrav
Ok, I think what you need is the 5340 bracket...Correct...
If so, I'll try to look up the Ford Part Number later this evening..(got to go do some things..Later, Trav..
Old Sep 11, 2013 | 09:58 AM
gomer450's Avatar
gomer450
mine looks a lot bigger than that but ill double check hurricane rains out there now ill get back to ya later as well thanks
Old Dec 3, 2013 | 03:06 PM
gomer450's Avatar
gomer450
whats your email I can send u a pic of what mine looks like
hijo202
Mar 7, 2011 03:39 PM
Turbotim2
Dec 30, 2009 01:03 PM
JM5034
Dec 11, 2008 06:26 PM
therifleman556
Oct 29, 2008 05:42 AM
beat76
Dec 23, 2003 01:04 PM
