Oil light issue
Old Sep 13, 2013 | 10:34 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Oil light issue
I am having an issue, with the oil light in my '80. I started My truck,after coming out of the store. I noticed the oil light had not gone out,so I pulled to level ground,to check oil level. It was full, as it was when I checked it yesterday. I started it back up, to listen to the engine, and there were no noises, it was running as smooth and quiet as it always has.So i got in,and drove on home.
The 300 engine in it has just over 1000 miles on a complete overhaul (had 500 on it when I bought it 10 months ago). I observed the light as I was driving , and it would go out, then come back on dim, and flickering, go out again,then come back on bright. I am thinking the oil pressure switch is going bad, am I right?
Old Sep 14, 2013 | 01:41 AM
Ken Blythen's Avatar
Ken Blythen
Not necessarily, but probably; what you describe is typical of how senders fail.
Old Sep 14, 2013 | 03:13 AM
FordFETruck's Avatar
FordFETruck
Had this problem on our van, gave us a good scare for a while since we were 100 miles from home. Change the sender. The engine would be thrashing by now if it wasn't the sender.
Old Sep 14, 2013 | 06:21 AM
truckertrav's Avatar
truckertrav
I would think that the sending unit has gone south...
Like was mentioned before, If you truly lost oil pressure, You would know..
Might be a good time to put a TEE in the block and install a manual gauge when you replace the idiot light sender...that way you have BOTH...Trav.
Old Sep 14, 2013 | 07:11 AM
78 & 87 Super Cab
Yeah, I might just do that. I agree, if I had lost pressure, I woulda heard one helluva noise
Old Sep 14, 2013 | 07:24 AM
Franklin2's Avatar
Franklin2
If the wire going to the sending unit has rubbed through somewhere and is touching metal somewhere, it will cause the same thing. When the sending unit loses pressure, it grounds the wire to turn the light on. So the wire touching somewhere will turn the light on also.
Old Sep 14, 2013 | 08:35 AM
ctubutis's Avatar
ctubutis
Exactly what I was gonna say... all you need to do is ground that wire anywhere along its length for that light to come on. Same for water temp and BRAKE warning lights.
Old Sep 14, 2013 | 10:54 AM
78 & 87 Super Cab
I can sure check that out
moneymike
Escape & Escape Hybrid
Dec 9, 2017 10:51 PM
michaelbarry
General Automotive Discussion
Nov 17, 2005 02:19 PM
BobKoos
1997 - 2003 F150
Oct 11, 2003 03:35 PM
thefeath
Aerostar
May 29, 2003 06:49 PM
sport
Nov 12, 2002 10:42 AM
