Sponsored by: Real Truck
Gas vs PSD
Old Aug 18, 2009 | 03:31 PM
  #1066
Johnny Langton's Avatar
Johnny Langton
Originally Posted by jdadamsjr
Ah, yes.....
those numbers are hard to measure for me
probably good real numbers for that scenario,
but not a statistically accurate measurement for comparisons
(and certainly unique measurements - gotta give u that ! )
what grade were you on ? downhill I can do better
60 foot, 1/8th mile, 1/4 mile ? those are more universal numbers that are usually used... even 0-60 is suspect usually....
Remember this one particular user here who was selling his wares and kept redefining the norms of measurement !!! I called him on it and I almost got banned because he was a sponsor
Somewhat like me saying I have 300 more kulas than you at peak rpm !
( I don't know what that means either )
You've got an SCT tuner,right? You can go collect the same identical info.
This was flat terrain,and the datalogs shown in that post's link was a 0-60 run in dry weather empty (7000lbs). 50-70 mph is much more repeatable with a heavy load since you take traction issues out of the equation,and that's what you typically see for acceleration/passing tests.
JL
Old Aug 18, 2009 | 03:39 PM
  #1067
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Diesel is still better
Old Aug 18, 2009 | 03:45 PM
  #1068
jdadamsjr's Avatar
jdadamsjr
Just took the time to read your linked posts JL...you KNOW some ****
I am far from knowledgeable....
haven't done a datalog on my sct since I first got it and worked with Innovative so he could learn how to tune it (guess I was one of the early adopters )
Will have to give that a try but
"Doing the math,that's 8.78-1.57 for a 0-60 time of 7.21 seconds."
that's not bad at all for our big buses !!! will have to see if I can replicate....
need to look for those time slips during my 8.9 eight.... IIRC it had something close to 60 mph - maybe the 330 ???? dunno.... but recall the 1.9 60 foot...
Old Aug 18, 2009 | 03:57 PM
  #1069
Johnny Langton
It's amazing what 4WD will do for traction,eh?
My Tbird pulls low 1.6 60's,and it feels like getting rear-ended by a garbage truck @60mph. SCT's LiveLink is the software you can use with your laptop to do datalogging and to view real-time data as you drive.
JL
Old Aug 18, 2009 | 04:08 PM
  #1070
jdadamsjr's Avatar
jdadamsjr
You do know YOU will be responsible for killing this thread, right ?
We CAN'T have logic and real numbers getting in the way of smoke and mirrors !!!
Last edited by krewat; Aug 19, 2009 at 07:59 AM. Reason: Removed political comment
Old Aug 18, 2009 | 06:03 PM
  #1071
Wagion's Avatar
Wagion
Logic is not allowed go home!
Old Aug 19, 2009 | 04:35 PM
  #1072
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Broncoholic1
What oil did you put in it Bill 15w 40?
I have been running the Mobile 1 since the first 6K
Little pricey but in the long run it is worth it. = Too late for you...
no, 10w40.
What do you mean" too late"? The truck runs fine with it.
Old Aug 19, 2009 | 04:42 PM
  #1073
bill11012's Avatar
bill11012
JL
That is cool. I am about to get one and did not know it could do that.
Old Aug 19, 2009 | 05:14 PM
  #1074
lew52's Avatar
lew52
It won't !!
Old Aug 19, 2009 | 05:21 PM
  #1075
bill11012's Avatar
bill11012
Why not? He said it would.
Old Aug 19, 2009 | 05:26 PM
  #1076
lew52's Avatar
lew52
Got to see it !!....Lew
Old Aug 19, 2009 | 07:11 PM
  #1077
bill11012's Avatar
bill11012
Got to see what? what are you saying.
Old Aug 19, 2009 | 08:34 PM
  #1078
krewat's Avatar
krewat
FTE Leadership Emeritus
It does do it. I've written software (quick script in UNIX) to suck in the data and do 0-60 times easily without manually doing it. I've done lots of other stuff with the data logging also, it's a lot of fun
Old Aug 20, 2009 | 08:27 AM
  #1079
Broncoholic1's Avatar
Broncoholic1
no, 10w40.
Don't they call for 5w20? V10's have very tight clearance in the mains & rods. Amsoil is good too.. It is too late BillIt is hard for a 40w to get to your valve train. Now your truck is only going to last 250,000
https://www.ford-trucks.com/forums/7...ar-v-10-a.html
Old Aug 20, 2009 | 08:30 AM
  #1080
Broncoholic1
In a green machine...
