Sponsored by: Real Truck
Gas vs PSD
Old Aug 24, 2009 | 03:50 PM
  #1171
04redstroker's Avatar
04redstroker
it actually was kinda fun.lol
I talked to buddy who has a 5.4 250 the other day and he laughed when i said that the bench racers are bettin on a 5.4 to outpull a diesel.lol And my other buddy that has a v10 which he uses to pull light loads for work is gettin out of it and into a diesel cuz he says the damn thing wont pull it self out of its own shadow.lol
maybe i got the fire stirred up again.lol
Old Aug 24, 2009 | 03:55 PM
  #1172
UrbanXX's Avatar
UrbanXX
The difference between the V-10 and the Power Stroke Diesel:
Spec's from a 2001 Excursion:
Horsepower Torque
5.4 255 @ 2500 RPM 350 Ft. Lbs.
6.8 310 @ 3250 RPM 425 Ft. Lbs.
7.3 250 @ 1600 RPM 505 Ft. Lbs.
6.0 325 @ 3300 RPM 550 Ft. Lbs. @ 1600 RPM this is for a 2004 model.
If you have a 3000 pound trailer and you want to take your girlfiend to the prom the 5.4 will do the job.
If you have a 3000 pound trailer and you want to take the whole class to the prom the 6.8 will do the job.
If you have a 3000 pound trailer and you want to take the whole school to the prom then the Power-Stroke Diesel will do the job.
And if you are in a hurry and have a heavy load then the 6.0 is the quickest route from point A to point B.
This is why the four combinations of engines make the Ford so unique. Each set up is designed to handel a different application. So, depending on your application whatever it may be, would make the difference.
Old Aug 24, 2009 | 03:59 PM
  #1173
T8R's Avatar
T8R
Originally Posted by bill11012
If you revved it, and gently let the clutch out the 5.4 would pull it ok.
I would rather pull it with a V10 still.
With my V10 i have lost traction on pavement pulling posts.
Really need a pallet in the back for weight.
I don't think I've seen more than a couple posts by bill that didn't include "I like / I prefer"... "my V10".... "because it's better / because it's better at...." (Yes, being a " 7.3" guy, this makes me a hypocrite, ... which is, as always, ok when I do it. )
Idea for a new PSD drinking game: (preferably with a designated driver) - Gather as many V10 and 7.3 guys as you can - and make them buy a round every time they utter the words "yeah, well my... " or mention their drive train in a drunkenly pious manner.
A similar game involves the pious or bragging individual doing the drinking. This version might be more affordable for anyone who loves their V10 or 7.3 as much as we do.
I'm hoping to make this a new tradition if I make it to the next tech day.
Old Aug 24, 2009 | 04:06 PM
  #1174
04redstroker
how come us 6.0s guys keep gettin left out. It makes more HP then the 7.3 and all the v10 are better arguments have been made against the 7.3(at least I havent seen someone do the math on the 6.0)
Old Aug 24, 2009 | 04:08 PM
  #1175
bill11012's Avatar
bill11012
Modular motor junkie
That is true, I love it and talk about it alot.
Old Aug 24, 2009 | 04:10 PM
  #1176
bill11012's Avatar
bill11012
We have not, but we should.
I compare my V10 to the 7.3 because of the year it was made.
Old Aug 24, 2009 | 04:12 PM
  #1177
bill11012's Avatar
bill11012
If a v10 cant tow it, that is one ****ing heavy shadow!
Old Aug 24, 2009 | 06:10 PM
  #1178
04redstroker
lol Ive had two buddies get out of there v10s for diesels. One went to a 7.3 and the other is lookin at cummins right now.
Old Aug 24, 2009 | 07:18 PM
  #1179
bucci's Avatar
bucci
Originally Posted by Crazy001
And this is why an automatic is recommended by most manufacturers for towing. You have to maliciously abuse your clutch to get a load like that moving. There is virtually no wear incurred if done with an automatic...torque converters are wonderful things!
"Virtually no wear", so then you could do that type of towing many times over the life span of the truck and not have to be concerned about the trans.
Don't forget you are talking about a load that is well beyond the design limits of the truck no matter what engine or trans it has. He didn't say what size truck he used, but even a '09 F550 2wd drw chassis cab with the 6.4 is rated in the low 20,000 lb range, well under the load being towed.
"There is virtually no wear incurred if done with an automatic..." please elaborate/explain that one.
Old Aug 24, 2009 | 07:53 PM
  #1180
FordxFour's Avatar
FordxFour
I would like to see this explanation also. There is no way anyone will convince me that taking a truck that you have to abuse the clutch to take off, switch it over to an automatic and cure all problems without additional wear on the automatic. If you're having to ride/abuse the clutch, you are either grossly overloaded or the truck isn't spec'd for the job.
Why are most folks scared of more gear. If you are towing alot, gear the truck appropriately. What good is a truck with 3.73's if you have to keep the OD locked out, manually shift it, and/or matt it to the floor to get over the next grade. Take the same truck, put something such as 4.30's under it get it up to speed, set the cruise, and enjoy the trip without the transmission constantly hunting or having to lock out the OD. And you will most of the time get better mileage also.
If I have to constantly think about what gear, OD on or off, or can't use the cruise, then I've got the wrong truck for the job.
Old Aug 24, 2009 | 08:03 PM
  #1181
Tom's Avatar
Tom
What I said. When a clutch slips it wears the friction materials within the clutch. Like rubbing two sticks together, there is wear there.
There is no friction clutch in a torque converter. It's a fluid coupling. Also, the TorqShift transmission is used in everything up to the F-550, and is used in combined weights up to 33,000 lbs. WITH the automatic transmission.
With the manual, the max capacity of a Super Duty is "only" 28,000 lbs.
Old Aug 24, 2009 | 08:26 PM
  #1182
FordxFour's Avatar
FordxFour
Crazy001, the point I was trying to make is that if you take a truck that is underpowered and/or under geared the automatic isn't a magic pill. The wear may not occur in the torque converter, however the rest of the transmission must be taken into consideration.
Old Aug 24, 2009 | 08:29 PM
  #1183
bucci's Avatar
bucci
It may have been what you meant but not what you said. I understand your point now. Nicely done, dancing through the tulips.
So, automatics don't have internal clutch packs, eh?
You are correct in what you listed for towing capacities between the manual and auto. It is about 4,000 to 5,000 lb difference on the F550.
That difference is probably because in order to boost the towing capacity up on the manual any further means a much higher friction compound. Meaning that you won't be able to ride out the clutch as easy without it grabbing harshly. Probably too much driveablity will be sacrificied. It's not that it can't be done.
Old Aug 24, 2009 | 08:36 PM
  #1184
04redstroker
My 05 dodge that i use to drag trailers has a full ceramic clutch. Its what i had to use to hold the power. It pulls fine except for backing up with a real heavy load, that takes a little practice.lol
Old Aug 24, 2009 | 08:41 PM
  #1185
bucci's Avatar
bucci
Right, you got more clamping power, but it took away a little of the driveablity, in your case in reverse.
