Sponsored by: Real Truck
Gas vs PSD
Old Aug 25, 2009 | 12:07 AM
  #1201
KelVarnson's Avatar
KelVarnson
Originally Posted by Rush117
Actually tractive force is what pulls objects up hills.
Split hairs much? What do you think creates that tractive force? Rear-wheel torque.
Higher hp motors do not necessarily produce more "rear-wheel torque"
At a given vehicle speed, a higher-horsepower motor, geared properly, is capable of producing more rear-wheel torque than a lower-horsepower motor. Translation: Better acceleration, and/or the ability to move a heavier load.
(it's actually called axle torque).
You can call it whatever you want, but it is the same thing. Same exact thing. Axle torque and rear-wheel torque will always be identical (unless you break an axle).
If you don't have enough low end torque to move the load, then what good is the higher horsepower? That was the point of redstrokers scenario.
And what was subsequently being pointed out was that an automatic might allow you to spin the motor up to its horsepower peak. If you can do that, the higher-horsepower motor would produce more rear-wheel torque than the lower horsepower motor. Regardless of the torque rating of the motor.
Old Aug 25, 2009 | 07:50 AM
  #1202
Broncoholic1's Avatar
Broncoholic1
If I was going to go with a Coal Burner = Cummins all the way
I will trade ya a V10 for one. 4.30 Auto 4x4.
Old Aug 25, 2009 | 09:05 AM
  #1203
brian42's Avatar
brian42
Veteran: Navy
Except they wrapped a Dodge around it . You know what they say, you can't polish a turd !
Old Aug 25, 2009 | 10:43 AM
  #1204
krewat's Avatar
krewat
FTE Leadership Emeritus
Well, you can, but your hands get all ****ty
Old Aug 25, 2009 | 11:37 AM
  #1205
Wagion's Avatar
Wagion
Well...
Well...http://dsc.discovery.com/videos/myth...ng-a-turd.html
Old Aug 25, 2009 | 11:57 AM
  #1206
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by Wagion
Now I've seen everything!
(I've been looking for a reason to use that smile forever! Thanks Wagion)
Old Aug 25, 2009 | 12:25 PM
  #1207
alchymist's Avatar
alchymist
"Mifflin Clay"
And no matter how much you polish it, it still won't shine!
Old Aug 25, 2009 | 12:29 PM
  #1208
jdadamsjr's Avatar
jdadamsjr
I will NOT watch that show.... talk about junk science !!!!
and that video makes it worse than that lol
Old Aug 30, 2009 | 02:23 AM
  #1209
snowtoad's Avatar
snowtoad
v-10 vs psd
u guys sure like to drag this out.
u no i have nothing to prove
after owning 3 v10 i have no disire to buy a dsl!
then i talk to guy that owns several psd dsl and he constantly in the shop fixing something on them. and he is a bussness man! u would think the man would get him self a v-10 and see how it does after spending several thousands of dollars fixing his psd's.
i whent almost 265000 before i had a miss fire. and after i found that problem im currently at almost 350000 on. the engine has never been crack open, except for valve covers and timing chain cover looking for miss fire. the intake was takin off and the intake ports look pretty clean. there was very little ware on the cams. this not babyed engine. i use to haul rvs all over usa and canada plus ak. the engine run in well past -20 degrees and was run wif it over 100 degrees all wif trl on its back. it never seen a wrecker!
MY FORD MECHANIC SWARES AND DECLARES THAT WILL GET 500,000 !!! we r not far from that. she is not rattling run pretty good im not sure if is as strong as my other v-10 i have. i change the oil every 4,000 miles wif couple qtr's of lucus synthic wif the semi blend.she uses a qt or so around 3 to 4,000. but she dosent smoke.
so u have to ask ur self is that dsl worth that 7,000+$[going higher] option? psd fuelmilage is not that spectacular. dsl fuel is higher and going higher. it cost more to fix them and serv. them. its very hard for me to justfy a psd. yea they will most likley out pull a v-10, but ur going to pay for that.
psd im not impressed.
Old Aug 30, 2009 | 07:28 AM
  #1210
Tom's Avatar
Tom
Snowtoad, good post. You just demonstrated a point that I've been trying to make all along. Everyone seems to act like the PSD engines will last forever, and that the gas motors are inherently inferior in this capacity.
I've tried to point out the guy with the million mile 5.4, but nobody pays much attention.
I, too, would love to see someone who's had such a painless ownership experience with a PSD over that many miles. That doesn't mean the PSD isn't a great engine, though. Just means that many of the diesel crowd doesn't understand that longevity isn't necessarily something it has over the V10.
Old Aug 30, 2009 | 09:10 AM
  #1211
bill11012's Avatar
bill11012
Modular motor junkie
that 5.4 is up to 1,100,000 miles now.
Old Aug 30, 2009 | 09:41 AM
  #1212
Mustang6147's Avatar
Mustang6147
Ilike my 5.4 3v... I have no desire to buy a V10 or a PSD...
I am looking forward to many many miles. I have had 302's and 351's, and put many miles on them. I am hopeing for the same with my 5.4
Old Aug 30, 2009 | 10:00 AM
  #1213
SteveBricks's Avatar
SteveBricks
FTE Emeritus
He said, as he bumped the thread and drug it out a bit more
Old Aug 30, 2009 | 10:19 AM
  #1214
Bear 1's Avatar
Bear 1
Smile
Compare apples to oranges
Old Aug 30, 2009 | 12:48 PM
  #1215
mudmaker's Avatar
mudmaker
By your statement I must be lucky with all of my psd's. My current pickup is at 190k and the only issue I have had is an oil leak which cost me $25 to fix. I think you guys tend to live in a fantasy land thinking psd's are in the shop all the time. Since I have owned my current pickup I have spent less than $1500 in repairs. The only repair to the motor was the oil leak mentioned. The rest of the repairs were from wear on the suspension components.
If the psd option is up to 7k that is crazy! IIRC I paid half that.
