Sponsored by: Real Truck
Gas vs PSD
Old Aug 24, 2009 | 08:49 PM
  #1186
KelVarnson's Avatar
KelVarnson
Originally Posted by bucci
It may have been what you meant but not what you said. I understand your point now. Nicely done, dancing through the tulips.
Come on, cut the guy a little slack. The example pointed out was a one-time severe overload, not everyday towing. And in that case there is a BIG difference between sitting there smoking a clutch, or heating up some tranny fluid.
Yes, if you did that all the time, an auto would suffer. But the post was clearly about using the auto transmission's ability to spool up the RPM into the powerband without burning up clutch material to do it.
Old Aug 24, 2009 | 08:50 PM
  #1187
bill11012's Avatar
bill11012
Modular motor junkie
Are yall saying an auto can tow more than the 6 speed?
Old Aug 24, 2009 | 08:52 PM
  #1188
06silvercrew's Avatar
06silvercrew
Originally Posted by Crazy001
What I said. When a clutch slips it wears the friction materials within the clutch. Like rubbing two sticks together, there is wear there.
There is no friction clutch in a torque converter. It's a fluid coupling. Also, the TorqShift transmission is used in everything up to the F-550, and is used in combined weights up to 33,000 lbs. WITH the automatic transmission.
With the manual, the max capacity of a Super Duty is "only" 28,000 lbs.
Sure there are friction clutches in a tq convertor, the viscous clutches. They can and will wear just like a clutch disk will.
  #1189
alchymist's Avatar
alchymist
"Mifflin Clay"
Actually the automatic transmission does suffer just as much as the manual. Loading the torque converter with that kind of load really generates the heat, and other internal parts generate more heat also. All this excess heat causes premature failure of the transmission. You can get away with it for a while, but it will eventually catch up with you, and bang,,,there goes a tranny.
Old Aug 24, 2009 | 08:53 PM
  #1190
06silvercrew
Thats exactly what hes saying and hes right. The auto's are rated higher then the 6spd
Old Aug 24, 2009 | 08:59 PM
  #1191
Tom's Avatar
Tom
Thanks! Comes with lots of practice!
So, automatics don't have internal clutch packs, eh?
It's not that they don't have clutch packs. It's that you don't slip them to get the load moving
That difference is probably because in order to boost the towing capacity up on the manual any further means a much higher friction compound. Meaning that you won't be able to ride out the clutch as easy without it grabbing harshly. Probably too much driveablity will be sacrificied. It's not that it can't be done.
I think it also has to do with transmission durability. Most medium duty manual transmissions are non synchronized. I believe this is because a transmission that can withstand that kind of load is going to have a very heavy rotating mass, which would be very hard on synchros. Going to a heavier, more durable, non-synchronized transmission would mean that almost nobody except a professional truck driver would know how to drive it
I think.
Old Aug 24, 2009 | 09:00 PM
  #1192
Rush117's Avatar
Rush117
Originally Posted by KelVarnson
Sigh... Here we go again. Torque AT THE REAR WHEELS is what pulls objects up hills. Assuming you have the right gearing (most trucks do), higher-horsepower motors will be able to produce higher rear-wheel torque, and do it at a higher rate of speed. Engine torque comparisons are just about meaningless at this point. Engine torque is literally only half of the equation.
Actually tractive force is what pulls objects up hills. Higher hp motors do not necessarily produce more "rear-wheel torque" (it's actually called axle torque). If you don't have enough low end torque to move the load, then what good is the higher horsepower? That was the point of redstrokers scenario.
In only a few more pages, a Ranger will be out pulling a F450 with a 6.4.
Old Aug 24, 2009 | 09:02 PM
  #1193
mudmaker's Avatar
mudmaker
They will unless you modify the clutch and pressure plate on the 6spd. The 6spds get really hot pulling heavy loads. If I had a 6spd and was using it to pull heavy I would have a trans temp gauge. When I had my hot shot setup I had a lot of pressure plate issues. They were all due to too much tranny heat.
Old Aug 24, 2009 | 09:06 PM
  #1194
bucci's Avatar
bucci
I think.
100% correct.
Old Aug 24, 2009 | 09:10 PM
  #1195
Tom's Avatar
Tom
If the Ranger had the V10 in it...and bill11012 were driving...with his 6-speed...
Old Aug 24, 2009 | 09:17 PM
  #1196
bill11012's Avatar
bill11012
I think.
I would still rather drive the 6 speed, it will out last the auto.
A clutch is easy to change and will last 100k with abusive driving.
Old Aug 24, 2009 | 09:19 PM
  #1197
bill11012's Avatar
bill11012
Haha You are right!!!
btw, I do not have a 6 speed, I just wish I did.
Old Aug 24, 2009 | 09:53 PM
  #1198
mudmaker's Avatar
mudmaker
It will last 100k miles as long as you arent pulling 20-30k down the interstate regularly. Then you get to change it every 15-20k miles. BTW, when the clutch goes out in the 6spd it is a crap shoot, sometimes it takes the intake shaft out and becomes a $2500 fix.
It would be great if they would offer a heavy duty manual tranny as an option. The auto is what, 1k dollar option. I would rather pay 1k extra for a manual tranny that was pretty much bullet proof.
Old Aug 24, 2009 | 10:19 PM
  #1199
hughjazz's Avatar
hughjazz
I think.
I'd be fine with that.
Old Aug 24, 2009 | 10:24 PM
  #1200
bill11012's Avatar
bill11012
i wish they would, but they my not even have a stick after 2011.
