Sponsored by: Real Truck
Gas vs PSD
Old Aug 23, 2009 | 11:37 PM
  #1156
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by KelVarnson
Oh boy. I'm gonna go make some popcorn
Agreed. I would want a 4wd in that case, to use low range.
It is true, There is a big power difference.
99- 03 7.3 235 HP.
05- 5.4 310 HP.
Old Aug 24, 2009 | 12:47 AM
  #1157
KelVarnson's Avatar
KelVarnson
99- 03 7.3 235 HP.
05- 5.4 310 HP.
Read some of my previous posts in this thread, you're preaching to the choir
Old Aug 24, 2009 | 09:25 AM
  #1158
Rush117's Avatar
Rush117
99- 03 7.3 235 HP.
05- 5.4 310 HP.
I believe you missed the entire point of the "torque is everything" debate. The situation redstroker described is about brute strength to pull an object up a hill. Torque is the brute strength and horsepower is how fast the strength can be applied. If you don't have the strength in the first place, it doesn't matter how fast you can apply it.
Old Aug 24, 2009 | 09:30 AM
  #1159
bill11012's Avatar
bill11012
How would the higher HP not Out tow the lower HP?
Torque helps, but that is to big a difference for it to make up for.
Old Aug 24, 2009 | 09:39 AM
  #1160
jdadamsjr's Avatar
jdadamsjr
MORE bench racing ?!?!?!
As Nike said - Just do it !
Jeeze Louise
Old Aug 24, 2009 | 10:14 AM
  #1161
KelVarnson's Avatar
KelVarnson
Sigh... Here we go again. Torque AT THE REAR WHEELS is what pulls objects up hills. Assuming you have the right gearing (most trucks do), higher-horsepower motors will be able to produce higher rear-wheel torque, and do it at a higher rate of speed. Engine torque comparisons are just about meaningless at this point. Engine torque is literally only half of the equation.
Old Aug 24, 2009 | 10:16 AM
  #1162
bill11012's Avatar
bill11012
You said it much better than me.....
Old Aug 24, 2009 | 10:35 AM
  #1163
04redstroker's Avatar
04redstroker
Yeah a 5.4 would pull it, once it was moving.lol I highly dought that a 2wd 5.4 would have even budged it. The 7.3 almost didnt keep traction and i was hardly givin it throttle. It might have started to move it you dumped the clutch at 5k, but the tires wouldnt hold. I just put it in low and let the clutch out till it started boggin and just gave enough throttle to keep the rpms just above idle.
Old Aug 24, 2009 | 12:04 PM
  #1164
KelVarnson's Avatar
KelVarnson
I could see how it could be an issue in a 5.4 manual, if you can't initially get the RPMs up high enough to get in the power band. An auto trans would help that, 4wd low-range would be even better.
Old Aug 24, 2009 | 01:38 PM
  #1165
bill11012's Avatar
bill11012
If you revved it, and gently let the clutch out the 5.4 would pull it ok.
I would rather pull it with a V10 still.
With my V10 i have lost traction on pavement pulling posts.
Really need a pallet in the back for weight.
Old Aug 24, 2009 | 02:40 PM
  #1166
Tom's Avatar
Tom
And this is why an automatic is recommended by most manufacturers for towing. You have to maliciously abuse your clutch to get a load like that moving. There is virtually no wear incurred if done with an automatic...torque converters are wonderful things!
Old Aug 24, 2009 | 02:49 PM
  #1167
bill11012's Avatar
bill11012
It depends on how it is geared. My 4R100 is crap tell 30mph the 1st gear is so high.
Old Aug 24, 2009 | 03:02 PM
  #1168
Mustang6147's Avatar
Mustang6147
Your whole post, is so true LOL... so so true.
Old Aug 24, 2009 | 03:29 PM
  #1169
04redstroker
I didnt have to ride the clutch long. Just the first few sec to get it rollin then i let it all the way out. Just didnt wanna bust a ujont or somethin so i kept it slow.lol The a$$ end of the truck was walkin side ways, but the tires wernt spinnin.lol I had to pull up the hill at an angle to the truck to stay out of the intersection and to make the turn to get off the main road.
Old Aug 24, 2009 | 03:44 PM
  #1170
bill11012's Avatar
bill11012
sounds fun. lol
