Starting Point
Old Mar 11, 2021 | 01:03 PM
  #256
cps's Avatar
cps
Originally Posted by F350towing
@cps
Thanks for that. Not sure if you kept reading through the thread after that post.
Since then Dan has done some work on my tranny as well as live tuned my truck.
my bad, i did not.
The guy that bought my truck put in 238/100 injectors in it and let me take it for a spin. WOW, unbelievable how much power it has.
Old Mar 13, 2021 | 09:44 AM
  #257
F350towing's Avatar
F350towing
Is there a cheat for the fuel line disconnect at the tank fittings when I drop it instead of buying the disconnect tool set.
Hard to justify the purchase since I can’t see ever using them again. I’m gonna go bug a neighbour and see if he has a set.
Still have to procure the 3/8 aluminum tubing, but have everything else gathered for the H & H.
How much time should I set aside for this, working on the ground, floor jack for lowering and raising the tank.
Old Mar 13, 2021 | 09:58 AM
  #258
FordTruckNoob's Avatar
FordTruckNoob
They’re less than $10.
Lisle 37000 Air Conditioning/Fuel Line Disconnect Tool Set https://smile.amazon.com/dp/B0002SRC...ing=UTF8&psc=1
Don’t use aluminum. It fatigue cracks with vibration.
Old Mar 13, 2021 | 10:02 AM
  #259
F350towing's Avatar
F350towing
That’s probably $30.00 for me landed cost.
Old Mar 13, 2021 | 10:04 AM
  #260
FordTruckNoob
Oh. I forgot about the whole Canada thing. Was it you I offered to meet in the woods?
Old Mar 13, 2021 | 10:07 AM
  #261
RacinJasonWV's Avatar
RacinJasonWV
It will eat up a big part of the day. Unless you’ve done it a couple times and are speedy. Seems like it took me and dad about 4 hours and this was my second time. But we didn’t get in any hurry and spent some extra time trying to clean the tank.
SSJ can probably do it in an hour with his experience level.
Don’t forget to cut the fill and vent tubes back for the Harpoon mod while in there. It was easily worth the $20 or so dollar investment for the pvc cutter, which I’ve used on other projects since.
Old Mar 13, 2021 | 10:24 AM
  #262
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The local parts stores sometimes have the tool on the shelf or as a loaner. I am not familiar with the parts stores in Canada though, so perhaps your options are limited.
Old Mar 13, 2021 | 10:25 AM
  #263
RacinJasonWV
These are just normal spring fitting disconnect tools I think. You should be able to get some locally without import costs. Have a Canadian equivalent to Harbor Freight?
Otherwise maybe a little rolled plastic sheet might work back in there to release the spring. Have a fairly thin plastic hose you can split and cut down to size? Without the proper tool you may spend a crazy amount of time working with something that should take 10 seconds though. Might consider blowing out and spraying with some penetrating oil before trying to get it off.
Old Mar 13, 2021 | 10:29 AM
  #264
RacinJasonWV
Some ideas.
https://www.google.com/search?q=fuel...&client=safari
Old Mar 13, 2021 | 11:38 AM
  #265
F350towing's Avatar
F350towing
Yeah that’s me.
Driving down to RDP in Oregon is closer than driving to meet you in the forest though, but thanks for the offer.
Found a cheap set local to me if my neighbour doesn’t have a set.
https://www.princessauto.com/en/9-pc-a-c-and-fuel-line-quick-disconnect-tool-set/product/PA0008947517
Old Mar 13, 2021 | 06:51 PM
  #266
SkySkiJason's Avatar
SkySkiJason
Nah, I’ve been using aluminum tubing for heated fuel lines for +15yrs now. Literally miles of the stuff in service, some for 100’s of 1000’s of miles. I run it inside heater hose and seal the coolant at the ends with compression fittings. This service (in-tank) will never, ever be an issue.
This is the ‘tube-in-hose’ termination I use. The aluminum tubing is inside the wire loom and runs continuously through the tees and heater hose. This system has a looped return, so (hot) fuel is returned to the suction line instead of returning to tank.
Old Apr 28, 2021 | 12:04 PM
  #267
F350towing's Avatar
F350towing
I have been collecting parts for the last couple of months and am now about ready to do some installations.
H & H the SSJ method. Prior to dropping the tank for this I will measure db of engine both at cold start and at operating temperature, then again once the H&H is done.
Once I get those readings I will move to under the hood installs. I generally like to do things one at a time so that there is always a base line to compare but with everything on the top end to be done that doesn’t make sense in this case.
Diesel O-Rings fuel bowl rebuild kit, RDP fuel lines, RDP JIC HPOP lines, RDP FRx.
Still gotta open up the CAI on the turbo and check it out for play. If there is any then KC Turbo 300x turbine wheel and 360° rebuild kit
Old Apr 28, 2021 | 02:42 PM
  #268
Sous's Avatar
Sous
FTE Emeritus
You have a solid course of action planned out and backup plans for when things get sideways. We look forward to the progress reports and pictures along the way!
Old Apr 28, 2021 | 07:13 PM
  #269
jgg123's Avatar
jgg123
Sounds like we are taking similar parallel paths in trying to improve the reliability of our trucks. I have my tank removed right now. Good thread!
Old Apr 29, 2021 | 08:55 AM
  #270
F350towing's Avatar
F350towing
As I go back and have re-read this thread, and have literally lurked 100’s of other’s
#1- I’m amazed at what I have learned in the past year.
#2- How awesome “this” community is. I spent a couple months researching prior to deciding which forum to join.
I’ve been talked down off the ledge a couple of times, and believe I’ve done the same for a couple of others.
A few times I’ve wished that I had an unlimited bankroll and could have just done everything at once, but hindsight is 20-20, and I would have made uneducated decisions and most likely would have paid someone else to do the job.
For some turning the key and knowing it starts is enough.
Knowing why and how the symphony of parts is orchestrated, now that is cool, diagnosing and fixing, even cooler. Besides the scraped knuckles and grime.
7 paragraphs
