Starting Point
Old Jun 14, 2021 | 06:48 AM
  #361
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by F350towing
All done with the airbags and test drive completed.
What a difference in the ride quality, so much smoother. Aired them up to 20psi for now.
Serviced the rear slide pins as well when I had the tires off.
Didn’t have my phone on me while I was doing the work so here is the completed installation picture.
That's a healthy looking airbag install. Is that picture taken with the truck sitting on its wheels?
Old Jun 14, 2021 | 08:39 AM
  #362
F350towing's Avatar
F350towing
Yes, on its wheels unloaded ride height at 20psi.
This is the second most favourite improvement I’ve done to the truck. It’s like I took 10 years off it’s life in ride quality.
Hydra with SDK live tuning still on top in #1 position.
Old Jun 14, 2021 | 08:58 AM
  #363
sjbj's Avatar
sjbj
Okay, so for clarification sake, what kit would we (I) need to fit my truck with the airbags over the leaf springs like that vs axle tubes like I have now? I have a 2002 F250 CCSB 4x4. Is it more cost effective you purchase a whole new kit (bags and all), or can you buy the individual parts (minus the bags) for affordable?
Old Jun 14, 2021 | 09:10 AM
  #364
FordTruckNoob
I’d say since you already have an air bag system and as long as your air bags have the appropriate range of articulation, just get the brackets to convert to outside the frame/over the leaf. @Sous found some over at etrailer.com. I think he posted about them earlier in this thread.
Old Jun 14, 2021 | 09:16 AM
  #365
F350towing's Avatar
F350towing
I had a heck of a time sourcing “ Parts” for the airbag system. I never went down the road of looking for the mounting plates, but my bet is that you won’t find them.
As for which kit, from what I can tell that depends on which 5er hitch you have in the bed.
We could have split the kit. You get the brackets, I get the plates and bags. Win- Win. The bags alone were $130.00 each.
Old Jun 14, 2021 | 10:06 AM
  #366
jgg123's Avatar
jgg123
dumb question, but what was the initial motivation for the bags? It looks like you have a fairly small TT for your truck.
edit: nvm. Broken bags from previous install.
Old Jun 14, 2021 | 10:32 AM
  #367
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@sjbj As I mentioned earlier in this thread, I will be removing (most likely) the AirLift over the axle mounts and building my own kit from parts and pieces of other kits in order to have an over the leaf spring mount for the 5000 series air bags.
My selection of parts will not be based on price or cheapest, but fitment and best suited. A complete new kit should not be required as that is not my intention and based on what I have seen thus far, a complete kit will not be required.
I have a half a page (Word Document) of notes and links ready to be utilized, once we return home. I would not want to speculate what the correct brackets, fasteners and spacers would be until I had some time to figure it out.
If you can wait a month until we are home, then I will likely have a comprehensive list of the parts required and where to get them.
If you cannot wait that long, I can email you my notes document and you can go to town.
Old Jun 14, 2021 | 10:40 AM
  #368
F350towing's Avatar
F350towing
@Sous @sjbj
Here is the stamped part # on the bottom mounting plates.
I tried to find one on the upper but since I didn’t remove them it was hard to get the camera in there and couldn’t get an image of that part #.
Old Jun 14, 2021 | 10:50 AM
  #369
Sous's Avatar
Sous
FTE Emeritus
@Sous @sjbj
Thank you for that, this is very helpful!
During traveling out west and after I identified the failure point of the current brackets, I was texting with a couple of friends. One of them sent me the following page on Etrailer.
https://www.etrailer.com/Accessories...ils=.questions
Etrailer has over a dozen upper brackets alone, then spacers, fasteners, lower brackets, connectors, etc. I don't have the time or drive to measure and figure out a solution right now while we are away from home, but if SJBJ wants to go at it I will gladly email my list of notes to him.
Old Jun 14, 2021 | 10:54 AM
  #370
ESwift's Avatar
ESwift
CNCFAB
Sous, since you already have ouo mounts and flipped u bolts, call Dave at ouo, he has some really, really nice bag mounts :-)
Old Jun 14, 2021 | 11:32 AM
  #371
Sous's Avatar
Sous
FTE Emeritus
I will do that sir. If not to only have more options and/or ways to accomplish the job.
I just want to do it right this time. I never liked the AirLift over the axle mount and years later this instinctive feeling has proven to be accurate. I always try to tell people to go with their gut feeling, but apparently I had to learn this lesson the hard way.
At least my comments were not a total derailment from the current topic of discussion within the thread.
More to follow and I will create a new thread once my plans materialize and I have a course of action set.
Old Jun 14, 2021 | 11:36 AM
  #372
F350towing's Avatar
F350towing
Switching gears now.
Michelin LTX on the steering axle. 10 years old. I checked the maintenance folder yesterday.
Surprisingly the drive axle tires are still in good shape considering what these look like. Maybe because of the dually fenders they have been shaded from the sun damage. Better than 60% tread left on them but the cracking is giving me a cause for concern.
Opinions???
Drivers side
Passenger side
Old Jun 14, 2021 | 11:43 AM
  #373
Sous's Avatar
Sous
FTE Emeritus
If the tires on any of our vehicles looked like that on the sidewall, I would replace them. Even my wife's convertible VW Beetle.
Sometimes we have to replace tires before they wear out due to age, it happens.
Old Jun 14, 2021 | 11:44 AM
  #374
FordTruckNoob
I would replace those tires if I were you. It will be cheaper than the wreck after they blow.
Old Jun 14, 2021 | 12:40 PM
  #375
F350towing's Avatar
F350towing
Ah yes. The flower power VW I’ve seen pictures of. I can only imagine the looks you got while blasting down the freeway all by yourself in it.
Currently doing some research on the replacement tires. They have to be an all weather tire since we have road restrictions on tires between October 1 and April 30 for 3-peak or M&S ratings.
At this point of my life tread wear is not important based on what is left on the existing takeoffs, but I don’t want them to look like a TRUCK TIRE and sing me a song down the road.
Nokian Rotiiva AT 235-85-16 @ $226 each.
Michelin Agilis Cross Climate @ $291 each.
