Starting Point
Old Aug 4, 2020 | 01:06 PM
  #166
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You are lucky to have shop/resource such as Dan (SDK) that close to you. Keep us updated!
Look at it this way, the $1000 you are about to spend is not even 1 months payment on a new 6.7L that belongs to the bank.
  #167
SkySkiJason's Avatar
SkySkiJason
The seal is $4. Up to 14qrts of Merc V at $5/qrt and $35? filter.
Its 4-5 hours labor - MAX.
Those prices are ludicrous... I can get a full rebuild for just a few $100 more.
Maybe they are replacing the pump instead of just the seal? Or throwing in a new triple disc billet TC?
Craziness....
Old Aug 4, 2020 | 01:10 PM
  #168
SkySkiJason
Everyone gets PHP library with hydra. You can get one for $300 and install it yourself...
I re-read your post and see (5) of his tunes.
Old Aug 4, 2020 | 02:18 PM
  #169
F350towing's Avatar
F350towing
Craziness....
Wecome to Canada EH!!! Wish I was around the corner from you instead. 6-7 hours at $120 per was the ballpark plus parts and taxes.
I Repeat!!! Welcome to Canada EH!!! After exchange on RR site the Hydra is over 600 cdn before shipping.
Old Aug 4, 2020 | 02:57 PM
  #170
SkySkiJason
Dammit man!!
Good thing you Canadians are all rich and can afford it!! Lol.
Yes, I forget how much more everything is there... I think 6-7 hours is high for a first time DIY’er - but if that’s what they get, whatcha gonna do??
Like Sous said, still less than a new truck payment and I’ve changed a few of those seals and transmission lasted a long time after.
Good luck and keep us posted! Anxious to hear how you like Dan’s tunes. Ask about boost fooler if you get a chance too.
Old Aug 4, 2020 | 04:00 PM
  #171
F350towing's Avatar
F350towing
Dammit man!!
I agree
I wish that were the case.
Told my wife the same thing last night. It’s cheaper to fix the truck we have than to take on payments for a newer truck. I would have to go used and then who knows what your getting.
If the crappy hypertech is any indication of what’s to come I think it will be hard to get the smile off my face.
I will ask about the boost fooler as well.
Old Aug 5, 2020 | 02:38 PM
  #172
F350towing's Avatar
F350towing
I asked about the boost fooler.
They open up the window on the map to 90 seconds prior to de-fuelling to prevent setting the code is what I was told.
“ It’s unlikely anybody would be in overboost for longer than that duration”.
Old Aug 5, 2020 | 04:51 PM
  #173
SkySkiJason
So boost fooler is not needed, but is highly recommended?
I forgot to have you ask about WG....
Old Aug 5, 2020 | 06:46 PM
  #174
F350towing's Avatar
F350towing
It wasn't Dan I was talking to this morning but one of his technicians. He didn't say either way, recommended or not when I asked if I may need one. Just said about the map window being extended to prevent overboost defuelling.
Last time I asked about the WG (a couple weeks ago) they don't recommend disconnect on a stock turbo with their tunes. He did mention something about a KC ,I think, being ok but that was again not with Dan.
I will have a good Q&A session with Dan when i pick it up. Hopefully I will remember all my questions. Maybe I'll take some notes with me, like an interview or something.
I dropped it off yesterday afternoon so hopefully should hear from him tomorrow.
Old Aug 7, 2020 | 07:03 PM
  #175
F350towing's Avatar
F350towing
Picked the truck up yesterday.
5 Hours for the re & re on the tranny, Not so bad.
Didn't get to have a GOOD test run on the tunes for 2 reasons.
# 1, It was raining off and on yesterday and wet roads don't work so well when trying to WOT.
#2 I forgot and left the transmission tuning from the Hypertech on the truck. Let's just say it wasn't happy with 2 different shifting strategies trying to work together, or against each other. TC lockup was way too soon.
Tomorrow I will get the hypertech shifts off the truck and let's see what happens with some dry roads.
Old Aug 7, 2020 | 08:04 PM
  #176
SkySkiJason
The hydra will over ride anything on the PCM.
The programmer has no effect on your new tunes.... There is no ‘stacking’ of tunes happening.
Old Aug 8, 2020 | 10:19 AM
  #177
F350towing's Avatar
F350towing
If that the case then there are some issues with his tunes that are currently loaded. Specifically the shift strategies.
Stock tune won’t shift.
40 Tow slams into second under moderate throttle.
In most tunes, if not all, just as the turbo starts to light in 3rd the tc locks up early and drops me out of the boost.
The power it has is much better and with OD off and rolling once it does light in 3rd I did see 28lbs. Not sure what tune. Less than 1/2hr behind the wheel and 6 tunes.
I did talk with Dan about it yesterday and having both tunes on the trans. He didn’t seem concerned and never mentioned that the hydra would override the PCM.
Old Aug 8, 2020 | 10:25 AM
  #178
SkySkiJason
Sounds like something is up with those tunes.
Put chip on ‘00’ and see how it shifts.
Old Aug 8, 2020 | 04:14 PM
  #179
F350towing's Avatar
F350towing
Dropped the Hypertech shift strategy today.
Shifted great in 00. Switched to 01 at a 4 way stop sign and it died. Back to 00 and it flashed up and got me out of there. 02 seemed hard shifts, then tons of slip. It’s bi-polar.
Going to test 04, 80hp Daily next but so far... this still ain’t right.
Old Aug 8, 2020 | 04:58 PM
  #180
F350towing's Avatar
F350towing
Picked my daughter up from work and 10 minutes to home. She asked what’s wrong with the truck.
Im sure it’s just a matter of wrong program for the PCM.
