1972 Highboy Build Progress
Old Sep 5, 2017 | 12:41 PM
  #601
F2501972's Avatar
F2501972
Broke down... need some help. I drove the truck about 15 minutes to town. Ran fine. Went to my meeting and came out. Truck started great and then loss of all power - everything. No lights, complete electrical power gone.
I have my light tester and some tools with me.
Does anyonw have their ears on right now? Thxs
Old Sep 5, 2017 | 12:45 PM
  #602
wizkid00104's Avatar
wizkid00104
I'd start at the battery. Check the terminals and the wires for corrosion. Or just wiggle them around. Next, I'd check the fuse box.
Old Sep 5, 2017 | 12:48 PM
  #603
wizkid00104
Is there a relay that supplies the power to the accessories? The ignition switch would have low current through it probably connected to a relay to supply power to internal accessories. I am not super familiar with this era of Ford though.
Old Sep 5, 2017 | 12:55 PM
  #604
F2501972's Avatar
F2501972
I checked the battery terminals and they are old but seem ok. How do I check the fuse box? THXS!
Old Sep 5, 2017 | 12:59 PM
  #605
wizkid00104
Here is the wiring diagram I found:
http://www.fordification.com/tech/wi..._F100-F350.jpg
From there, I would follow the positive battery wire until you reach what I would guess is the power distribution box. It is almost completely at the left of the diagram I linked. It shows fuse links there... If you disconnect the fuse you can run resistance check of the fuse. Short circuit or no resistance means the fuse is good.
  #606
F2501972's Avatar
F2501972
There is a solenoid which does have power to it. That comes from the batt and then goes on to the starter.
Old Sep 5, 2017 | 01:01 PM
  #607
wizkid00104
One think I can tell you about old terminals is the look fine and you get a good reading off of them. But when they are put under load, the voltage has a significant drop because of the resistance in the metals between the battery posts and the wiring. They are also made of different metals (lead vs copper for example) and when dissimilar metals are used they can create galvanic corrosion. This is why it is a nightmare to remove steel fasteners from an aluminum engine block.
Old Sep 5, 2017 | 01:02 PM
  #608
wizkid00104
Will the truck crank?
  #609
F2501972's Avatar
F2501972
I have a test light on me but no other tester tools.
Old Sep 5, 2017 | 01:05 PM
  #610
wizkid00104
Ok. Try the test light on the starter solenoid where 12V batter wire connects. For the ground, use a bare spot on the engine block. This should tell you if the engine has a good ground and there is power to the solenoid.
Old Sep 5, 2017 | 01:15 PM
  #611
F2501972's Avatar
F2501972
Light came on so that is good to go...
Old Sep 5, 2017 | 01:17 PM
  #612
F2501972's Avatar
F2501972
No crank... Its like the batt is gone. No electrical power to any of the systems.
Old Sep 5, 2017 | 01:18 PM
  #613
F2501972's Avatar
F2501972
Old Sep 5, 2017 | 01:20 PM
  #614
F2501972's Avatar
F2501972
  #615
wizkid00104
You can try jumpering the posts on the solenoid with a screwdriver. If the truck starts, then it was the solenoid.
Your battery may have gone because the alternators bad. You drove in using juice but not recharging it. You got jumper cables?
