1972 Highboy Build Progress
Old Jun 29, 2017 | 10:04 PM
  #496
F2501972's Avatar
F2501972
1) RV grind cam. The cam is a speed pro split duration 282/292 lift is .485/.511 which Jim says will be a torque beast. Lobe center 112 deg also for low end torque.
I started to put the differential back in and was reminded I need a shop press lol. Found a used one on craigslist. I could use a friends press but I would like to have one handy. Although I hope to hit it right the first time it might take a time or two to hit the right shim stack.
2) Hyper pistons
3) Federal mogul bearings and gaskets
Jim is on the lead with the engine parts etc.
What do you guys think about the list so far?
Old Jun 29, 2017 | 10:07 PM
  #497
F2501972's Avatar
F2501972
Old Jun 30, 2017 | 10:47 AM
  #498
bajafishnut's Avatar
bajafishnut
It all looks like quality parts, and what about lifters, push rods, and the head work... stiffer
valve springs , triple angle valve grind, and so on.... Easy does it amigo, take you time, and do it right the first time...
Looks good so far...
baja
Old Jul 1, 2017 | 10:40 AM
  #499
F2501972's Avatar
F2501972
Do the rubber mounts pull apart? I have the bolts out front and back but the upper and lower parts seem firm. This is one of the back mounts under the gas tank (which I have out)
This is the front one and the rubber looks pretty flat compared to the back.
Old Jul 1, 2017 | 10:54 AM
  #500
F2501972's Avatar
F2501972
Jeff, where can I find the metal parts for those cab mounts? Or will the old ones come apart?
Looks like there is an upper metal retainer and a lower metal retainer. Based on the diagram, I can not tell if they just pull apart or if they have threads.
You are correct the rubber is really bad on the rad support as well. So my lines are going to be off until I figure out the rubber.
Old Jul 1, 2017 | 02:13 PM
  #501
F2501972's Avatar
F2501972
Old Jul 1, 2017 | 03:45 PM
  #502
bajafishnut
Looking great amigo, and the brass freeze plugs are always a nice touch...Love that Ford blue...
Baja
Old Jul 1, 2017 | 06:23 PM
  #503
F2501972's Avatar
F2501972
That part on the steering has more play than I think it should. The powersteering was not original. Brad had it installed when he bought from my grandfather. So what part does that look like and should it have some play? Thxs
Old Jul 1, 2017 | 08:46 PM
  #504
bajafishnut
Mine has a similar style U-joint, but my gear box used 4 bolts and I mounted i lower in the frame, so my steering shaft has less of an angle. Shouldn't make any difference though, and the U-joints should not have any play..
Baja
Old Jul 2, 2017 | 08:32 PM
  #505
fe390pc's Avatar
fe390pc
I would look at going to a 1978 or 79 F250 4x4 steering box conversion. Your steering linkage will be in proper alignment and have a much better box too. Those two wheel drive boxes are not as strong and will twist the main shaft trying to turn those big tires off road.
Just my two cents.
Old Jul 2, 2017 | 09:34 PM
  #506
pchelp's Avatar
pchelp
Originally Posted by F2501972
Hey F250, would you help me with an issue I may have on my 390? Could you look at your block and tell me if there is a ridge in the journal that the dipstick tube seats in? I am trying to determine if there is a bit of an old tube stuck down there or is it sleeved maybe
Old Jul 3, 2017 | 10:13 PM
  #507
F2501972's Avatar
F2501972
Just my two cents.
fe390, According to Jegs its a 1973 to 1979 F150-F350 unit. So it must be a 2WD power steering unit. I'll do a search for the 78 or 79 4x4 conversion. If you have a link to one please post.
Thxs for the tip!
Old Jul 3, 2017 | 10:20 PM
  #508
F2501972's Avatar
F2501972
Jim is doing most of the engine work. I'll send him a message and ask. On one hand it looks like a clean tube but I would think the dipstick would need more area to attach.
Old Jul 4, 2017 | 01:55 PM
  #509
F2501972's Avatar
F2501972
Thxs for the tip!
Well, I may have spoke to soon. I called back Jegs after looking up the rag joint part becuase the image was not correct. That guy said the part I ordered was for a GM. Have no idea what happened but the guy gave me a number to
The PowerLine 866-637-2787 He said they can look it up and find the part. I looked at every rag joint on ebay and nothing matches my rag joint. I went on YouTube and found a clip where a guy had a 69 Ford truck and he put a 1979 Powersteering unit on and his rag joint is a match to mine. So, I'm stumped as to why it is so hard to find this part. I might be better off to put the old one back on and do the conversion fe390 was talking about down the road.
Thoughts? Thxs
Old Jul 4, 2017 | 06:52 PM
  #510
fe390pc's Avatar
fe390pc
Technically that is not a rag joint. If it is worn out the best thing to replace it with will be a Borgeson Shaft.
Amazon Amazon
Others may chime in here with another option.
Here is the rebuild kit for the joint you have.
Lower Manual Shaft Joint Assembly Repair Kit 1973-79-Broncograveyard.com
The 1978/9 F250 steering box is this,
1979 Ford F Series Trucks Power Steering Gear Box F200-350 [3/4. 1 ton] 4WD Model - With Power Steering 82-00295 AN
